Red & green lines top & bottom
Had a senior moment and playing with my new phone. Installed some software that shows bars at the bottom and top in red & green. Bouncing around as the phone does things. Some app that I now don’t know how to uninstall.
Can anyone help me to get rid of them please? They are seriously annoying… ;-(
I guess you enabled developer tools?
Your description sounds like you enabled frame rate display.
Open Settings -> Developer tools and set Frame rate display to Off.
Thank you kind Sir!
Saved my sanity… :wink:
Guten Rutsch
