I have just activated my third SFOS device, Xperia 10 III. While installing all necessary apps, I miss the former Recorder App in jolla Store. This app seems to be no longer available. Why that? I was using this simple app quite frequently on my XA2 and it showed very good results including flac codec. For my needs, the currently available recorder app in store, Audio Recorder, is simply not good enough. Any idea, where I can find the old Recorder App? There it was possible to select the recording codecs Vorbis, Speex, PCM and FLAC.
Probably because there aren’t any aarch64 version. Sounds like the app is not maintened anymore. Try to find the sources to compile an aarch64 version.
Do you mean: Recorder | OpenRepos.net — Community Repository System which is available for 64 bit devices at: Recorder | OpenRepos.net — Community Repository System
I would recommed to listen to @pherjung , buuuuut
you could explore third-party app repositories which is risky, but the decision belongs to you to weight if the risk is worth it
Source is here…
Correct, this is the recorder I am looking for. Anyone here who can be so kind and generate the apk for me? I am a novice in this.
That’s quite the wrong package format.
Why that? Normally, when I install an application, I take an apk file. … if I don’t install it from a store.
That’s the format for Android.
And while SFOS can run Android apps, the native apps are really nothing like that.
Sailfish uses rpm, like e.g. Fedora Linux.
Ok, understood. Anyway, neither rpm nor apk is part of the source above.
The second link I posted above contains links rpm files for your device.
Hallelujah. Thanks a lot. It works perfectly. Yippie.
mee too! Thanks very much!
Is it possible to add LAME encoder to this for encoding mp3 files?
edit: where are the recorded files? I can’t find them. Playback in the app works fine but copying recordings to a NAS or accessing recordings from computer/sftp would be fine!
Regarding LAME: Ask your question to elvarr via Recorder | OpenRepos.net — Community Repository System , mentioned above.
Regarding storage of recorded files: You find them under defaultuser/Documents/Recordings . The link within the recorder app doesn’t work. Use the files app (Dateiverwaltung).
Thanks @KJM ! Found it. Recordings inside documents in fact! I made a symlink from /home/defaultuser/ to have it easier to access.
And, playback from inside the app works fine on my side. What did you mean with: ‘link within recorder app doesn’t work’ ?
