and it works with the latest versions of SailfishOS. I know, I’m using it as a daily driver. I am not using the older Adnroid layer for this phone though.
There is Hutspot in the Openrepos (I recommend installing Storeman for easy access). You need Spotify Premium to use it. It needs some configuration but I think it is pretty manageable for someone who flashed SFOS in a phone. Hutspot does not have all the functions of the official app but it is sleek to use like Sailfish itself (I like it better than the official).
Did you know if there is any option to support the xz1 compact? (I had before that mobile, and currently my girlfriend had mine)
I like the X compact, but I don’t know with the old android support, maybe it become only to a test experience and I cannot convert it into daily (personal) phone.
Hutspot is not compatible with 4.3, as it’s using openssl 1.0 (If I remember correctly) and cannot be installed anymore… Also, it was not working fine for me, the librespot was not connecting automatically…
