So… how long it’s been in total since that broken signal level algorithm was introduced? A year already?
Dear Jolla, why not simply go back to the old one (that at least worked, whereas what we now have is just a PLACEHOLDER) if for any reason you can’t fix it?
No, I did not. But I’ve had 5 others, where it worked fine.
Anyway, if the problem was C2 only, then it should have been fixed on the C2 only, rather than messed up everywhere else. And left so for almost a year now…
Yeah, I had 7 others before C2, too, but who’s counting. At some C2 time I started to realise that the signal strength used sometimes to be not full when using any earlier Sailfish device, but no more with C2. However, no idea what would be the case with JP2026. I think I had a look at the related code changes at some point and they didn’t look like something that would be totally straightforward to create device-specific workarounds for. I myself don’t think that spending a lot of effort to create a partial-revert-workaround is justified here, but you may of course disagree as much you want.
Honestly, I really don’t care HOW, I’m merely saying that a year (if not more) should have been more than enough to make such a most basic mobile telephony feature work again on all the devices where it wasn’t even broken before they ‘fixed’ it. Including Jolla’s current flagship, which also got infected with this plague. Even my Xperia 1 IV is plagued with this as it also spread to all community ports.
According to the original post, the bug was introduced in 5.0.0.73, which
2026-02-06 5.0.0.73 Released to Early Access users as OTA update
So, definitely “(if not more)” than a year yet. 8 months and 2 days. Sure, I agree that it would be nice to have this one working, but you emphasising on the “year” thing just requires me to nitpick that it doesn’t seem to be even 3/4ths of a year yet.
The original post merely states when the original poster discovered that issue and not when it objectively appeared. I’ve definitely seen it reported elsewhere as encountered earlier, but - mind you - I won’t bother to waste time looking for it now especially for you. Regardless of whether it’s actually ‘a year (if not more)’ or ‘just’ 8 months, it simply should’ve been fixed, especially where it wasn’t even broken in the first place. Not to even mention infecting newly released devices and ports, including even Jolla’s flagship.
Now kindly excuse that I won’t continue arguing with you. Enjoying my freedom to have and voice my own opinion, I’ve said mine and that’s it. Have a nice evening.
My point here is: I believe you are a sensible person. If you have all the required skills and facts readily available to build a proper argument, you should do that. Not come up with some imaginary timeframes, that’s what AIs do. Spreading misinformation is not ok, not even about things that are not nice.
Sorry for my multiple edits. Now this message is perfect enough.
Me being ‘sensible’ or not doesn’t change a thing about the actual bug, which in an attempt to get fixed on a single device that was the only one originally affected, first got spread to all other devices and ports and eventually even to JP2026, and then just left like that on all of them for many months, no matter if 12 or ‘just’ 8, and several major (and multiple minor in between) OS updates from 5.0.x.x up to 5.2.x.x. And counting, as nothing indicates that anything is being done about it as we talk.
A properly working signal level indication is one of the most basic (i.e. mandatory) and very much needed feature, especially in places with signal coverage issues where one would otherwise be able to use the indicator as an aid to locate a good spot.
By stubbornly steering this discussion away from the actual problem (the bug having not been given proper attention accross at least almost the entire 2026) towards nitpicking and assessing my personality traits you’re muddying the waters and clouding the actual issue.
Yeah, it definitely doesn’t change a thing about the actual bug, that’s a very valid assessment. Neither does complaining about it here, either, it seems. But that doesn’t matter, forum paper is cheap.
You list many proper points that I haven’t disagreed on. I think they are very much enough for your argument, without needing anything non-factual to be added. Good!
Myself, I don’t like this bug, but I don’t care about it as much as you do. On it not being yet fixed, I can easily build me a coherent mental model of explanations - backed with my own experiences, observed code changes and my understanding of software development in general and Jolla as a company - why it was introduced and not yet fixed which makes me content enough on that. But that’s just a mental model that keeps myself completely happy, not something I’d even consider trying to transmit to anyone else.
However, as this is a real issue, I believe statements regarding it that I know to be non-factual deserve to be corrected. Now that they are, I have nothing more to add at the moment. You can now continue not arguing with me and enjoying your freedom in peace.
More than 200 words (in that latest post alone, I won’t even count all the rest) to say nothing of anyone’s concern other than it’s been 8+ rather than 12 months, a true masterpiece of graphomania.
Could someone create an adjustment where users could tweek signal strenght as they please? Or select between 3-4 signal strenght profiles? Or is that blocked from Sailfish to tinker with?
I did some searching and found the qml file responsible for the strength indicator (/usr/lib64/qt5/qml/Sailfish/Settings/Networking/MobileNetworkStatusIndicator.qml).
However, the component seems to translate the strength percentage from ofono to the bars correctly. Ofono just always returns 1 as the signal strength (as a value from 0-100).
I’m gonna go take a walk around the town and see if it ever changes.
Alright I’m back, and Ofono never reported any signal strength above 27%. After going outside, it hit 27%, then 17%, and then levelled off at 22%. It stayed there the whole time until I went back inside, at which point it went back to 1%.
Now I did carry an Android phone with me as well, but, like a doofus, I forgot there wasn’t any simcard in there, so I’m not entirely sure what the strengths it measures represent. It certainly isn’t the same cell tower as the Jolla phone anyway. Gonna try again later with simcards in both, also logging the cell tower it connected to.
No, I just logged the strength from the dbus service with a loop and dbus-monitor. I’ll try the SystemDataScope method tomorrow, a graph would be nice.
Edit: by dbus service I mean org.ofono.NetworkRegistration.
