On the Jolla C2, the signal bar for 4G appeared to be hardcoded to 100% before the actual update 5.0.0.76. Now, it usually shows one bar most of the time, but it rarely goes up to 2 till 4 of the 5 bars when near the antenna towers of my carrier.
I compare it to Android with the same carrier: when you connect there to WLAN, the bars increase (Voice over WLAN?), so this seems to be a form of manipulation regarding signal strength when using WLAN on Android. Therefore, this is not really comparable 1:1 to SFOS, and I’m starting to believe that SFOS shows the true reality of the signal strength.
While signal strength is important for maintaining a connection, signal quality is crucial for ensuring that the connection remains reliable and efficient. A device can show strong signal bars but still experience poor performance if the quality is low.
Is seems that SFOS displays signal strength rather than signal quality. Since I have no issues with mobile data connections or VoLTE calls in quality, this appears to be some kind of “cosmetic error”.
I only have one bar on the C2 as well, but no problems with telephony. During a car ride, I was able to see on the radio display, at the beginning of a call, the immediate rise of the signal strength to the maximum with the hands-free system. When idle, I can get up to 2 bars at most.
Got the same issue with 5.0.0.76 and 5.0.0.77. Can’t say everything works OK though, as I’m constantly having major issues with this connectivity bug that’s discussed elsewhere in the forum.
You do realize such a possibility that the .77 release has been the first and only 5.x OS version that I’ve ever had on my 10 III, for as simple reason as that it got updated all the way up from 4.6.0.x directly to 5.0.0.77, in one go. So, in all your wisdom, please kindly explain how could I have reported having this issue on any other 5.x.x.x OS version but the only one I’ve used.
org.nemomobile.ofono.CellInfo.GetCells returns an empty array ([] ).
The org.nemomobile.ofono.CellInfo interface exists, but it provides no cell information.
Despite these values, LTE works perfectly well.
I downloaded a 100 MB test file over LTE and achieved an average download speed of about 4.6 MB/s (~37 Mb/s) , with no connection drops during the test. This makes me think that the reported signal strength is not reflecting the actual radio conditions.
So my observations are very similar to those described earlier in this thread: extremely low reported signal strength, but normal LTE performance.
Is anyone using Sailfish OS 5.1.x on an Xperia 10 III (or another supported Xperia) seeing a correctly working signal strength indicator? If so, could you please mention your device model and Sailfish OS version?
It would be useful to know whether this is still a general issue or if it has been fixed on some devices.
No, it has not been fixed since February. It even propagated to community ports, like a plague. Clearly, they don’t consider it important enough, whereas even just temporarily going back to the old algorithm (that worked very well for me on all SFOS devices I’ve ever owned) would be better than having this useless permanent 1-bar ‘indicator’ regardless of the actual signal strength.
Took a half year break from SFOS as my Xperia 10 II needed a new battery and some other maintenance, but I kept postponing… Anyhow, after successful maintenance, I updated to the most recent version and yeah, the same issue appears with the signal indicator - it shows 1 bar practically all the time. Cellmon does show that Network Registration RSSI % is from 1-10% (mostly lower end), while Cell RSSI % shows around 70% most of the time.
The cell’s signal strength is always on a bar. When I’m on a 5G network, there are sometimes two or three bars. But nothing more. So the error still exists.
