Rainviewer does not show map
OSVERSION: 4.6.0.15
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.1.14 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: not specified
Upon starting the application, there is no map loaded, only a black screen is given with a play button and a time axis on the bottom.
Mapbox GL is installed and maps are loading without problems in different navigation apps, such as Pure Maps and OSM Scout on the same device (Xperia 10 iii)
Rainviewer installed via Storeman or Chum
  1. Open the app
  2. See that no map is loaded within 5 min
EXPECTED RESULTS:
Map is loaded and display within the Rainviewer app after app launch. See Screenshots on the Rainviewer Storeman / OpenRepos or Chum entry
ACTUAL RESULTS:
No map loaded and displayed, only black emptiness
  • Patchmanager: no
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.10+git7
![Screenshot_20241122_120146_001|214x500](upload://ybYhhVKTssKR5FrPpXrNTS9AH7E.png)
The tag bug-report is only for Sailfish
Do you have OSMscout Server maps installed? It’s the same for me if I select that.
If I select OpenFreeMap Bright - presto it works.
Have a look in Settings…
You’re right, with OSM Server maps are loading.
I am sorry that I have overseen this dependency.
Therefore, how to proceed? Close this bug report? This is my first bug report, so please excuse me, if this is a stupid question.
I am sorry that I confused this. Can I correct this?
