Is it possible to define 2 different layouts that the app will swicth between depending on phone orientation?
The documentation only mentions changing the layout/anchor locations based on isPortrait but if what if I say want to convert a Column into a Row or vice versa or change the hierarchy of elements?
You can’t make a Column become a Row, but you can use things like a Flow.
Something like:
Flow {
width: parent.width
height: parent.height
Column {
width: (isLandscape) ? ( parent.width / 2) : parent.width
Column {
Or you could use a Loader to do completely different things depending on orientation.
Component { id: portraitLayout
Column { ... }
Component { id: landscapeLayout
Row { ... }
Loader {
sourceCompnent: isPortrait ? portraitLayout : landscapeLayout
Or with something like a Grid and a Model, just set the rows/columns depending on orientation:
Grid {
columns: isPortrait ? 1 : 3
Repeater {
model: whateverModel
delegate: GridItem { ... }
Thanks, I’m going to checkout both options for my usecase (I’m guessing that a Loader might produce a “hickup” in the userexperience), I had this vague memory that it was possible with some builtin property to define a landscape and a portrait layout maybe that is still from the n900/n9 days…
There’s also something called State in QML which I have seen used for portrait/landscape layout switching. Never used it myself though. Flow also works for some cases, that I have used.
This works;
import QtQuick 2.6
import Sailfish.Silica 1.0
Page {
allowedOrientations: Orientation.All
SilicaFlickable {
anchors.fill: parent
Column {
anchors.centerIn: parent
visible: isPortrait ? true : false
Rectangle { width: 300; height: width; color: "red"
Label { text: "Portrait"; anchors.centerIn: parent }
Row {
visible: isLandscape ? true : false
Rectangle { width: 300; height: width; color: "green"
Label { text: "Landscape"; anchors.centerIn: parent }
For now I used the Flow solution, will experiment with others, I think the “double” Row/Column solution with conditional visibility would not work for me because I have a VideoOutput of which you can only have one instance as far as I recall.
Is there a property that gives the absolute height/width of the screen? ie. height: screenHeight or somehing similar? (Or a list of builtin properties in SFOS)
Do the properties of Screen do what you need?
