Is anyone already working on a Qi charger TOH for the 2026 Jolla Phone? I didnt look much, but it doesnt look all that hard to implement. I’m interested in taking a stab at implementation unless efforts are already ongoing - does anyone know if this is already being worked on?
I noticed the power restrictions. I’m not well read up on Qi charging (yet) - but IIRC 15W is a common charging power in several chargers and phones. We couldn’t reach that high due to the restrictions you mention.. But I think we should still be able to get a lower power version (5W?) for e.g. charging over night (which incidentally is my primary use-case).
This is the only feature missing from JP26 that my previous phone had and thanks to having it the usb-c port is in great condition after 8 years of use. I tried a few no name qi chargers that connects to the port but they all have an annoying electrical hum that wasnt present on the built in qi charger.
How would you approach sourcing a decent qi charging circuit?
Due to the speed limitations I think maybe a decent approach that might work for some (for sure for me) might be using an existing wireless charging pad with a type c connection.
You can definitely do that right now and have it placed between the phone and the case, but I would really be interested as well in a more elegant solution like a TOH.
The current pogo pin speed might sound ok-ish, but 8 hours of wireless charging this huge battery with 9W feels more like waiting for your EV to charge at night than your phone.
I would be perfectly happy with slow charge Qi ToH. My phone sits in exactly two locations at my home 80% of the time so if those two had wireless charging it would not matter if it is slow.
My initial thought is to use something like a FPC from JLCPCB and to copy a reference circuit from e.g. Microchip (such as AN3532 + a charging coil from Wurth, such as 760308102207). 760308102207 is a bit thick (1.2mm) - but OTOH this seems to be a popular choice and there are reference designs using it.
Not sure how to handle the actual plastic “back-plate” of ToH - perhaps an initial prototype could be 3d-printed.. But I worry about the plastic tabs/hooks holding the plate to the phone. I don’t think the electronics can be made thin enough to just cram this in between the ToH which came with the phone.
I wouldn’t mind it being a screw into place TOH nor 3d printed as I don’t see myself needing any other one…with the silicone case on it wont feel any different in the hand as well!
i am also in the same boat. i have somewhat started building a couple ToHs (ToH breadboard adapters, battery extender, garage opener, ir blaster, lora antenna, long range wifi wlan via halow, etc.). But it feels like i can’t be the literaly first human to attempt to build such a thing. so it feels weird starting from scratch.
no matter tho. maybe suboptimal results comapred to what others are making (which i can not find) but still fun to develop
This is definitely something I see many throwing money at I don’t understand everything, but with quick math if we can achieve max 9W power through TOH, battery is ~21Wh, that is a little over 2h from 0-100%. I think point of this TOH is that when you come for your desk in office you can easily place your phone on charger and pick it as easily when needed without cable hassle. Or when you are driving, sleeping etc. I will patiently wait to see one of these
I did some research on 9W Qi charging. I’m sorry to say this does not really seem feasible.
5W Qi (“Baseline Power Profile”) charging seems relatively straight-forward. There are lots of chips around for this from different manufacturers, and there’s (seemingly) not that much complexity in terms of protocol or calculations.
For >5W, we enter “Extended Power Profile” territory. For this, we need to perform some calculations (e.g. “foreign object detection”) and communicate with the Qi charger via the shared magnetic field.
My thinking is that supporting the EPP could be feasible if there was a suitable chip which could be purchased and designed around, leaving all the FOD, communication, etc. to firmware inside said chip. I found two seemingly feasible alternatives; one from ST (STWLC38JRM) and one from Kinetic Technologies (KTE7001).
I reached out to ST and Kinetic, and got basically the same response from both; they won’t support low-volume designs, and implementing around these chips without their support is apparently not feasible. I’ll take their word for it.
ST used to have design resources (eval boards, firmware, firmware flashing utils) available to all customers but withdrew this a while back to only support high-volume customer - I am assuming the chips were causing large support efforts.
Going down the route of designing an EPP-capable Qi receiver around an MCU as I indicated in my earlier post seems too daunting given that the silicon vendors don’t even want to support their fully integrated solutions.
I’m now considering whether 5W charging is worthwhile or not. Any thoughts on that?
EDIT: I should note that 5W is the best-case scenario with perfect alignment of the phone over the charger - in practice we’re probably looking at less, since you won’t always place the phone in an ideal position.
Well, in case if I imagine the optimal situation 5W charging. For me that would probably still be enough, I’m at my desk over 6h at least during work day. Same for sleep. I can see my battery being quite full all the time with even that. I don’t have that much experience, but I would imagine 0-50% loss in efficiency depending of alignment. That could start to be a little low, but I don’t have experience of real values here. In case of max around 20% loss, I would still be happy with 4Wh/h charging rate
The phone charges in about 2H with 30W and above decent wired chargers.
With 9W (probably 5 unless you know a specific charger that will push 1.8 A in 5V) would get you about 8h of charging time, depending on the charging curve, efficiency and heat.
Having your phone heat up for 8h straight doesn’t sound like a great idea to me mostly for the battery, but each to their own ofc.
While I’m used to wireless charging for a decade, for this device I’ll probably print a stand to house an actual type c cable that can align the phones position while dropped, similar to how the switch dock aligns but probably prettier.
The charging on j2 still needs some adjustments and fixes, so it doesn’t inspire enough confidence for experiments yet. Also the fact that the phone needs to be like a landline, glued to the wireless charger for 8h is completely meaningless for my use case.
