Q: How can I force the GPS module to immediately switch on and start searching satellites on turning on Location in upper menu - and NOT waiting until a GPS request comes from some app like e.g. GPSInfo, Pure Maps or OSM Scout?
Can I edit some config file or some editable code to make the GPS power on/off exactly following the Upper Menu Location setting (on is on and off is off) and not wait for some running GPS user app?
I know that this was made for saving power but I would prefer to switch manually, so I could start GPS a little time before I really need it and give it time to position fix.
Many thanks for hints!
