Q: 'Do not disturb' - If ON, Clock Alarm works but Calendar Alarm not. How to let Calendar alarm bypass DND?
If ‘Do not disturb’ is set, Calendar alarms don’t sound, but Clock alarms do sound.
How can I let Calendar alarms bypass DND by tweaking in the qml files or other system configuration? Is there a way?
I’ve set the ‘Do not disturb’ mode permanently, for purpose that only calls from contacts do ring. Other (spam) calls don’t, that’s good. But at the moment I can’t use Calendar alarms in this setting.
Thanks for any hint!
edit: to clarify this, I would like to have with DND set to ON:
Clock alarm: ON
Calendar alarm: ON
E-Mail alarm: ON
Messenger alarm: ON
SMS from contacts: ON
Phone calls from contacts: ON
SMS from non-contacts: OFF
Calls from non-contacts: OFF
And also many thanks for any hint, where the program logic for this is located in the qml files (/usr/share/lipstick-jolla-home-qt5/* ?)!
Good question. I have some appointments in the morning that I set a “1 hour before” reminder for as I normally don’t use an alarm and I also normally have DND on during the night.
Does the calendar alarm sound on your device with DND on?
And, what device and what SFOS version?
Heh, I haven’t dared to try it yet! Your post basically told me I shouldn’t.
I don’t think this stuff is handled anywhere in qml, apart from setting/clearing the dconf key which indicates dnd is enabled (/lipstick/do_not_disturb).
It must be handled by something like mce, or profiled, or whatever dsme does.
Most likely profiled. There is a tool called profileclient which apparently allows to set most of the things you mention.
Maybe play around with that.
Searched hard for it, but can’t find it. Not in Storeman, Chum, nor in the Jolla cheatsheets and guides. Please give me a hint. Thank you very much!
It’s a cli tool and it has its own package:
zypper install profileclient
or
pkcon install profileclient
and then
profileclient -v
It may also be worth it to check out the defaults in /etc/profiled/50.sailfish_default.ini, and what happens in ~/.config/profiled when different modes are engaged. (Note: on older SFOS releases, user config was in ~/.profiled.)
Please note though that profiled and all its configuration comes from the Nokia/Meego days. There will be things in this which look or sound like they are working, but are not actually used under modern Sailfish OS.
Thanks, @nephros ! Installed profileclient successfully on both X10 phones:
Daily X10 with 4.5.0.25 and
Tinkerphone X10 with 5.0.0.68 .
Both phones the same: profileclient says,
calendar.alert.enabled = On (BOOLEAN)
calendar.alert.tone = /usr/share/sounds/jolla-ringtones/stereo/GaryMiau3.ogg (SOUNDFILE)
while DND is set to ON, and alarm shows on screen but no sound.
The blocking seems to be on another point.
With DND set to OFF and same settings for the rest, Calendar alarm works
Next I’ll have a look into mcetool
edit: unfortunately I found nothing.
edit: can this be because of the ‘Ringtone’ flag?
            "displayName"   : "GaryMiau3",
            "fileName"      : "GaryMiau3.ogg",
            "category"      : "Ringtone",
            "aliases"       : [ "" ]
Use Situations app (when: Calendar or Calendar Pro, what: Do not disturb - off).
Situations app (from Jolla store, by hhaveri) always says: App is disabled. Start it? (german: Anwendung ist deaktiviert. Aktivieren?) in a yellow banner at the bottom of the screen.
Tap on the banner closes the app.
After the next start, the same again.
I did make a reboot after installation.
Is Situations suitable for old 32 bit Xperia 10?
Works great on XA2 (32-bit).
But there is information here that might be useful.
You may want to try installing different (including older) versions of the program from here.
Sorry, all this Situations APP stuff is much too complex for solving this simple Problem:
