There are no entries in this log with or without verbose output in /etc/sysconfig/pulseaudio
So strace gives the following:
execve("/usr/bin/pulseaudio", ["pulseaudio", "--daemonize=no", "-n", "--file=/etc/pulse/arm_droid_defa"...], 0x7fe93f7c18 /* 55 vars */) = 0
prctl(PR_GET_DUMPABLE) = 1 (SUID_DUMP_USER)
newfstatat(AT_FDCWD, "/dev/__properties__", {st_mode=S_IFDIR|0711, st_size=3800, ...}, 0) = 0
faccessat(AT_FDCWD, "/dev/__properties__/property_info", R_OK) = 0
openat(AT_FDCWD, "/dev/__properties__/property_info", O_RDONLY|O_NOFOLLOW|O_CLOEXEC) = 11
fstat(11, {st_mode=S_IFREG|0444, st_size=47220, ...}) = 0
mmap(NULL, 47220, PROT_READ, MAP_SHARED, 11, 0) = 0x787801d000
close(11) = 0
mmap(NULL, 7440, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x787801b000
prctl(PR_SET_VMA, 0, 0x787801b000, 0x1d10, 0x786f2a2334) = 0
openat(AT_FDCWD, "/dev/__properties__/properties_serial", O_RDONLY|O_NOFOLLOW|O_CLOEXEC) = 11
fstat(11, {st_mode=S_IFREG|0444, st_size=131072, ...}) = 0
mmap(NULL, 131072, PROT_READ, MAP_SHARED, 11, 0) = 0x786f5f6000
close(11) = 0
futex(0x786f342030, FUTEX_WAKE_PRIVATE, 2147483647) = 0
mprotect(0x786f6de000, 409600, PROT_READ) = 0
mprotect(0x786f67a000, 409600, PROT_READ) = 0
mprotect(0x786f742000, 409600, PROT_READ) = 0
munmap(0x786f616000, 409600) = 0
openat(AT_FDCWD, "/dev/__properties__/u:object_r:exported_default_prop:s0", O_RDONLY|O_NOFOLLOW|O_CLOEXEC) = 11
mmap(NULL, 131072, PROT_READ, MAP_SHARED, 11, 0) = 0x786f65a000
close(11) = 0
openat(AT_FDCWD, "/dev/__properties__/u:object_r:exported2_default_prop:s0", O_RDONLY|O_NOFOLLOW|O_CLOEXEC) = 11
mmap(NULL, 131072, PROT_READ, MAP_SHARED, 11, 0) = 0x786f63a000
close(11) = 0
openat(AT_FDCWD, "/odm/lib64/hw/audio.primary.pdx213.so", O_RDONLY|O_CLOEXEC|O_PATH) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/vendor/lib64/hw/audio.primary.pdx213.so", O_RDONLY|O_CLOEXEC|O_PATH) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/system/lib64/hw/audio.primary.pdx213.so", O_RDONLY|O_CLOEXEC|O_PATH) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/odm/lib64/hw/audio.primary.XQ-BT52.so", O_RDONLY|O_CLOEXEC|O_PATH) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/vendor/lib64/hw/audio.primary.XQ-BT52.so", O_RDONLY|O_CLOEXEC|O_PATH) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/system/lib64/hw/audio.primary.XQ-BT52.so", O_RDONLY|O_CLOEXEC|O_PATH) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/odm/lib64/hw/audio.primary.sm6350.so", O_RDONLY|O_CLOEXEC|O_PATH) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/vendor/lib64/hw/audio.primary.sm6350.so", O_RDONLY|O_CLOEXEC|O_PATH) = 11
fstat(11, {st_mode=S_IFREG|0644, st_size=616224, ...}) = 0
readlinkat(AT_FDCWD, "/proc/self/fd/11", "/vendor/lib64/hw/audio.primary.s"..., 4095) = 40
newfstatat(AT_FDCWD, "/vendor/lib64/hw/audio.primary.sm6350.so", {st_mode=S_IFREG|0644, st_size=616224, ...}, 0) = 0
close(11) = 0
openat(AT_FDCWD, "/vendor/lib64/hw", O_RDONLY|O_CLOEXEC|O_PATH) = 11
fstat(11, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
readlinkat(AT_FDCWD, "/proc/self/fd/11", "/vendor/lib64/hw", 4095) = 16
newfstatat(AT_FDCWD, "/vendor/lib64/hw", {st_mode=S_IFDIR|0755, st_size=4096, ...}, 0) = 0
close(11) = 0
faccessat(AT_FDCWD, "/vendor/lib64/hw/audio.primary.sm6350.so", R_OK) = 0
mprotect(0x786f6de000, 409600, PROT_READ|PROT_WRITE) = 0
mprotect(0x786f67a000, 409600, PROT_READ|PROT_WRITE) = 0
mprotect(0x786f742000, 409600, PROT_READ|PROT_WRITE) = 0
mmap(NULL, 409600, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x786f125000
prctl(PR_SET_VMA, 0, 0x786f125000, 0x64000, 0x786f7e9b90) = 0
newfstatat(AT_FDCWD, "/vendor", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/vendor/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/vendor/lib64/hw", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/vendor/lib64/hw/audio.primary.sm6350.so", {st_mode=S_IFREG|0644, st_size=616224, ...}, AT_SYMLINK_NOFOLLOW) = 0
getuid() = 100000
socket(AF_UNIX, SOCK_STREAM, 0) = 11
connect(11, {sa_family=AF_UNIX, sun_path="/tmp/patchmanager-socket"}, 26) = 0
write(11, "/vendor/lib64/hw/audio.primary.s"..., 40) = 40
read(11, "/vendor/lib64/hw/audio.primary.s"..., 4095) = 40
close(11) = 0
openat(AT_FDCWD, "/vendor/lib64/hw/audio.primary.sm6350.so", O_RDONLY|O_CLOEXEC) = 11
readlinkat(AT_FDCWD, "/proc/self/fd/11", "/vendor/lib64/hw/audio.primary.s"..., 4096) = 40
fstatfs(11, {f_type=EXT2_SUPER_MAGIC, f_bsize=4096, f_blocks=1242024, f_bfree=559430, f_bavail=542537, f_files=320000, f_ffree=285504, f_fsid={val=[3066403536, 218546122]}, f_namelen=255, f_frsize=4096, f_flags=ST_VALID|ST_NOATIME}) = 0
pread64(11, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0p\3\0\0\0\0\0"..., 64, 0) = 64
mmap(NULL, 688, PROT_READ, MAP_PRIVATE, 11, 0) = 0x78781a9000
mmap(NULL, 1984, PROT_READ, MAP_PRIVATE, 11, 0x96000) = 0x787818f000
mmap(NULL, 5856, PROT_READ, MAP_PRIVATE, 11, 0x86000) = 0x786f638000
mmap(NULL, 31696, PROT_READ, MAP_PRIVATE, 11, 0x8000) = 0x786f630000
newfstatat(AT_FDCWD, "/vendor/lib64/lib64", 0x7fdc4c3208, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/lib64", 0x7fdc4c3308, 0) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/hw/lib64", 0x7fdc4c3208, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/hw/lib64", 0x7fdc4c3308, 0) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/odm", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/odm/lib64", {st_mode=S_IFDIR|0755, st_size=12288, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/odm/lib64/libbase.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
socket(AF_UNIX, SOCK_STREAM, 0) = 12
connect(12, {sa_family=AF_UNIX, sun_path="/tmp/patchmanager-socket"}, 26) = 0
write(12, "/odm/lib64/libbase.so", 21) = 21
read(12, "/odm/lib64/libbase.so", 4095) = 21
close(12) = 0
openat(AT_FDCWD, "/odm/lib64/libbase.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/libbase.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(12, "/vendor/lib64/libbase.so", 24) = 24
read(12, "/vendor/lib64/libbase.so", 4095) = 24
close(12) = 0
openat(AT_FDCWD, "/vendor/lib64/libbase.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/odm/lib64/egl", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/odm/lib64/egl/libbase.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(12, "/odm/lib64/egl/libbase.so", 25) = 25
read(12, "/odm/lib64/egl/libbase.so", 4095) = 25
close(12) = 0
openat(AT_FDCWD, "/odm/lib64/egl/libbase.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/hw/libbase.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(12, "/vendor/lib64/hw/libbase.so", 27) = 27
read(12, "/vendor/lib64/hw/libbase.so", 4095) = 27
close(12) = 0
openat(AT_FDCWD, "/vendor/lib64/hw/libbase.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
write(2, "library \"libbase.so\" not found", 30library "libbase.so" not found) = 30
write(2, "\n", 1
) = 1
newfstatat(AT_FDCWD, "/apex", {st_mode=S_IFDIR|0755, st_size=880, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/apex/com.android.vndk.v30", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64", {st_mode=S_IFDIR|0755, st_size=12288, ...}, AT_SYMLINK_NOFOLLOW) = 0
newfstatat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64/libbase.so", {st_mode=S_IFREG|0644, st_size=254024, ...}, AT_SYMLINK_NOFOLLOW) = 0
getuid() = 100000
write(12, "/apex/com.android.vndk.v30/lib64"..., 43) = 43
read(12, "/apex/com.android.vndk.v30/lib64"..., 4095) = 43
close(12) = 0
openat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64/libbase.so", O_RDONLY|O_CLOEXEC) = 12
readlinkat(AT_FDCWD, "/proc/self/fd/12", "/apex/com.android.vndk.v30/lib64"..., 4096) = 43
fstat(12, {st_mode=S_IFREG|0644, st_size=254024, ...}) = 0
fstatfs(12, {f_type=EXT2_SUPER_MAGIC, f_bsize=4096, f_blocks=27722, f_bfree=7, f_bavail=0, f_files=608, f_ffree=13, f_fsid={val=[45755353, 2338072633]}, f_namelen=255, f_frsize=4096, f_flags=ST_VALID|ST_RDONLY|ST_NODEV|ST_NOATIME}) = 0
pread64(12, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0\360\0\0\0\0\0\0"..., 64, 0) = 64
mmap(NULL, 688, PROT_READ, MAP_PRIVATE, 12, 0) = 0x786f62f000
mmap(NULL, 6736, PROT_READ, MAP_PRIVATE, 12, 0x3d000) = 0x786f62d000
mmap(NULL, 1840, PROT_READ, MAP_PRIVATE, 12, 0x3b000) = 0x786f62c000
mmap(NULL, 20148, PROT_READ, MAP_PRIVATE, 12, 0x3000) = 0x786f627000
newfstatat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64", {st_mode=S_IFDIR|0755, st_size=12288, ...}, 0) = 0
newfstatat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64/lib64", 0x7fdc4c3208, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64/lib64", 0x7fdc4c3308, 0) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/odm/lib64/libcutils.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
socket(AF_UNIX, SOCK_STREAM, 0) = 13
connect(13, {sa_family=AF_UNIX, sun_path="/tmp/patchmanager-socket"}, 26) = 0
write(13, "/odm/lib64/libcutils.so", 23) = 23
read(13, "/odm/lib64/libcutils.so", 4095) = 23
close(13) = 0
openat(AT_FDCWD, "/odm/lib64/libcutils.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/libcutils.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(13, "/vendor/lib64/libcutils.so", 26) = 26
read(13, "/vendor/lib64/libcutils.so", 4095) = 26
close(13) = 0
openat(AT_FDCWD, "/vendor/lib64/libcutils.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/odm/lib64/egl/libcutils.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(13, "/odm/lib64/egl/libcutils.so", 27) = 27
read(13, "/odm/lib64/egl/libcutils.so", 4095) = 27
close(13) = 0
openat(AT_FDCWD, "/odm/lib64/egl/libcutils.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/hw/libcutils.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(13, "/vendor/lib64/hw/libcutils.so", 29) = 29
read(13, "/vendor/lib64/hw/libcutils.so", 4095) = 29
close(13) = 0
openat(AT_FDCWD, "/vendor/lib64/hw/libcutils.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
write(2, "library \"libcutils.so\" not found", 32library "libcutils.so" not found) = 32
write(2, "\n", 1
) = 1
newfstatat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64/libcutils.so", {st_mode=S_IFREG|0644, st_size=70344, ...}, AT_SYMLINK_NOFOLLOW) = 0
getuid() = 100000
write(13, "/apex/com.android.vndk.v30/lib64"..., 45) = 45
read(13, "/apex/com.android.vndk.v30/lib64"..., 4095) = 45
close(13) = 0
openat(AT_FDCWD, "/apex/com.android.vndk.v30/lib64/libcutils.so", O_RDONLY|O_CLOEXEC) = 13
readlinkat(AT_FDCWD, "/proc/self/fd/13", "/apex/com.android.vndk.v30/lib64"..., 4096) = 45
fstat(13, {st_mode=S_IFREG|0644, st_size=70344, ...}) = 0
fstatfs(13, {f_type=EXT2_SUPER_MAGIC, f_bsize=4096, f_blocks=27722, f_bfree=7, f_bavail=0, f_files=608, f_ffree=13, f_fsid={val=[45755353, 2338072633]}, f_namelen=255, f_frsize=4096, f_flags=ST_VALID|ST_RDONLY|ST_NODEV|ST_NOATIME}) = 0
pread64(13, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0p\0\0\0\0\0\0"..., 64, 0) = 64
mmap(NULL, 688, PROT_READ, MAP_PRIVATE, 13, 0) = 0x786f626000
mmap(NULL, 8016, PROT_READ, MAP_PRIVATE, 13, 0x10000) = 0x786f624000
mmap(NULL, 7312, PROT_READ, MAP_PRIVATE, 13, 0xf000) = 0x786f622000
mmap(NULL, 12050, PROT_READ, MAP_PRIVATE, 13, 0x1000) = 0x786f61f000
newfstatat(AT_FDCWD, "/odm/lib64/libtinyalsa.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
socket(AF_UNIX, SOCK_STREAM, 0) = 14
connect(14, {sa_family=AF_UNIX, sun_path="/tmp/patchmanager-socket"}, 26) = 0
write(14, "/odm/lib64/libtinyalsa.so", 25) = 25
read(14, "/odm/lib64/libtinyalsa.so", 4095) = 25
close(14) = 0
openat(AT_FDCWD, "/odm/lib64/libtinyalsa.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/libtinyalsa.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(14, "/vendor/lib64/libtinyalsa.so", 28) = 28
read(14, "/vendor/lib64/libtinyalsa.so", 4095) = 28
close(14) = 0
openat(AT_FDCWD, "/vendor/lib64/libtinyalsa.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/odm/lib64/egl/libtinyalsa.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(14, "/odm/lib64/egl/libtinyalsa.so", 29) = 29
read(14, "/odm/lib64/egl/libtinyalsa.so", 4095) = 29
close(14) = 0
openat(AT_FDCWD, "/odm/lib64/egl/libtinyalsa.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
newfstatat(AT_FDCWD, "/vendor/lib64/hw/libtinyalsa.so", 0x7fdc4c2368, AT_SYMLINK_NOFOLLOW) = -1 ENOENT (Aucun fichier ou dossier de ce type)
getuid() = 100000
write(14, "/vendor/lib64/hw/libtinyalsa.so", 31) = 31
read(14, "/vendor/lib64/hw/libtinyalsa.so", 4095) = 31
close(14) = 0
openat(AT_FDCWD, "/vendor/lib64/hw/libtinyalsa.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (Aucun fichier ou dossier de ce type)
write(2, "library \"libtinyalsa.so\" not fou"..., 34library "libtinyalsa.so" not found) = 34
write(2, "\n", 1
) = 1
close(11) = 0
close(12) = 0
close(13) = 0
munmap(0x786f61f000, 12050) = 0
munmap(0x786f622000, 7312) = 0
munmap(0x786f624000, 8016) = 0
munmap(0x786f626000, 688) = 0
munmap(0x786f627000, 20148) = 0
munmap(0x786f62c000, 1840) = 0
munmap(0x786f62d000, 6736) = 0
munmap(0x786f62f000, 688) = 0
munmap(0x786f630000, 31696) = 0
munmap(0x786f638000, 5856) = 0
munmap(0x787818f000, 1984) = 0
munmap(0x78781a9000, 688) = 0
munmap(0x786f125000, 409600) = 0
openat(AT_FDCWD, "/dev/__properties__/u:object_r:log_tag_prop:s0", O_RDONLY|O_NOFOLLOW|O_CLOEXEC) = 11
mmap(NULL, 131072, PROT_READ, MAP_SHARED, 11, 0) = 0x786f61a000
close(11) = 0
openat(AT_FDCWD, "/dev/__properties__/u:object_r:logd_prop:s0", O_RDONLY|O_NOFOLLOW|O_CLOEXEC) = 11
mmap(NULL, 131072, PROT_READ, MAP_SHARED, 11, 0) = 0x786f5d6000
close(11) = 0
clock_gettime(CLOCK_REALTIME, {tv_sec=1733914632, tv_nsec=542719498}) = 0
socket(AF_UNIX, SOCK_DGRAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0) = 11
connect(11, {sa_family=AF_UNIX, sun_path="/dev/socket/logdw"}, 110) = 0
getuid() = 100000
gettid() = 8831
writev(11, [{iov_base="\0\177\"\10pYg\n>Y ", iov_len=11}, {iov_base="\6", iov_len=1}, {iov_base="vndksupport\0", iov_len=12}, {iov_base="Could not load /vendor/lib64/hw/"..., iov_len=95}], 4) = 119
clock_gettime(CLOCK_REALTIME, {tv_sec=1733914632, tv_nsec=543865852}) = 0
getuid() = 100000
gettid() = 8831
writev(11, [{iov_base="\0\177\"\10pYg\374\273j ", iov_len=11}, {iov_base="\6", iov_len=1}, {iov_base="HAL\0", iov_len=4}, {iov_base="load: module=/vendor/lib64/hw/au"..., iov_len=62}], 4) = 78
ioctl(2, TCGETS, 0x7fdc4c48c0) = -1 ENOTTY (Ioctl() inappropré pour un périphérique)
write(2, "E: [pulseaudio] droid-util.c: Fa"..., 100E: [pulseaudio] droid-util.c: Failed to load audio hw module audio.primary : Argument invalide (22)
) = 100
ioctl(2, TCGETS, 0x7fdc4c4ae0) = -1 ENOTTY (Ioctl() inappropré pour un périphérique)
write(2, "E: [pulseaudio] module.c: Failed"..., 198E: [pulseaudio] module.c: Failed to load module "module-droid-card" (argument: "rate=48000 hw_volume=false unload_call_exit=true output_voip_rx=false record_voice_16k=true"): initialization failed.
) = 198
munmap(0x786fafd000, 131536) = 0
munmap(0x786fadc000, 132008) = 0
munmap(0x786fa89000, 131784) = 0
munmap(0x786faaa000, 202192) = 0
munmap(0x786fa48000, 262360) = 0
munmap(0x786fa27000, 131144) = 0
munmap(0x786f9ef000, 226056) = 0
read(10, "", 4096) = 0
close(10) = 0
faccessat(AT_FDCWD, "/usr/lib64/pulse-14.2/modules/module-droid-glue.so", F_OK) = -1 ENOENT (Aucun fichier ou dossier de ce type)
faccessat(AT_FDCWD, "/usr/lib64/pulse-14.2/modules/module-droid-hidl.so", F_OK) = 0
openat(AT_FDCWD, "/usr/lib64/pulse-14.2/modules/module-droid-hidl.la", O_RDONLY) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/lib/module-droid-hidl.la", O_RDONLY) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/usr/lib/module-droid-hidl.la", O_RDONLY) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/lib64/module-droid-hidl.la", O_RDONLY) = -1 ENOENT (Aucun fichier ou dossier de ce type)
openat(AT_FDCWD, "/usr/lib64/module-droid-hidl.la", O_RDONLY) = -1 ENOENT (Aucun fichier ou dossier de ce type)
faccessat(AT_FDCWD, "/usr/lib64/pulse-14.2/modules/module-droid-hidl.so", R_OK) = 0
openat(AT_FDCWD, "/usr/lib64/pulse-14.2/modules/module-droid-hidl.so", O_RDONLY|O_CLOEXEC) = 10
read(10, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
fstat(10, {st_mode=S_IFREG|0755, st_size=68232, ...}) = 0
mmap(NULL, 131624, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 10, 0) = 0x786fafd000
mprotect(0x786fb00000, 114688, PROT_NONE) = 0
mmap(0x786fb1c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 10, 0xf000) = 0x786fb1c000
close(10) = 0
mprotect(0x786fb1c000, 4096, PROT_READ) = 0
ioctl(2, TCGETS, 0x7fdc4c5430) = -1 ENOTTY (Ioctl() inappropré pour un périphérique)
write(2, "E: [pulseaudio] module-droid-hid"..., 100E: [pulseaudio] module-droid-hidl.c: Couldn't get hw module functions, is module-droid-card loaded?
) = 100
ioctl(2, TCGETS, 0x7fdc4c53d0) = -1 ENOTTY (Ioctl() inappropré pour un périphérique)
write(2, "E: [pulseaudio] protocol-dbus.c:"..., 156E: [pulseaudio] protocol-dbus.c: Assertion 'p' failed at ../src/pulsecore/protocol-dbus.c:1116, function pa_dbus_protocol_unregister_extension(). Aborting.
) = 156
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
rt_sigprocmask(SIG_BLOCK, ~[RTMIN RT_1], [], 8) = 0
getpid() = 8831
gettid() = 8831
tgkill(8831, 8831, SIGABRT) = 0
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=8831, si_uid=100000} ---
+++ killed by SIGABRT +++
Aborted
