Protective soft case made in Austria for the Jolla phone 2026
Hi everyone, we’d like to let you know that our flip case – which has already protected the first-generation Jolla smartphones – is now available to order from our online shop at a special price for all licensed designs. We’d also love to produce a flip case featuring the legendary code design – perhaps someone could help us with that?
Probably get in touch with @rainemak regarding using the code design for a flip case.
I do like that you’re releasing a case for the Jolla Phone 2026 after you also made one for the original Jolla Phone :slight_smile:
Hey Florian - this is great!!
Just to let you know, I live in Graz and own two J2s.
If you need the physical thing for some reason let me know and we can meet.
I also have the Inari Blue ToH which is a little thicker than the regular one.
(I also have a C2 if that is of interest.)
HI, thank you for the offer, I hope to receive mine this week. I’m already working on some tests with 3D printing of the ToH. It all looks very promising.
…and produces a light which can be pleasant to see through small holes or any transparent surface.btw. :face_savoring_food:
I wonder if it would be possible to make a “Book” style cover, perhaps permanently attached to a (custom) ToH?
You could print something like that as one main structure (cover, hinge and TOH in one). There are some designs like that for other phones available but I personally would go for a “living hinge” approach for the bendy part.
Keeping the cover neatly closed would be a bit of an issue, though. AFAIK, there are no magnets present in the JP2, so you would have to integrate some in the side of the TOH and the cover which would make both a bit wider/thicker than they otherwise would have to be. Should be entirely possible, though. Of course, you could also combine materials - design a rail and/or a hole pattern in the 3d-printed TOH to make it easy(er) to attach a fabric/leather cover flap, for example.
@hazimuki79 your soft case looks awesome and I LOVE that it’s hand-made in Europe! I don’t like slide-in covers, otherwise I would order one. :slight_smile:
@hazimuki79: I’m definitely interested in getting one of those once I have my device. One question though: Will the phone still fit into your flip case when it has the official protective cover attached to it?
Hello, yes, the option is requested during order processing.
Hi, is there any progress on the case featuring the code design? It just looks amazing!
We would also like to produce, but we dont get any answer from Jolla HQ.
I highly recommend to ping either @Jolla or Jolla employees here in the forum. Maybe even send them private message
