[Proposal] TOH bumper with soft filament
TOH could be made to serve as a protective cover. I primarily want protect the screen from flat-hits, and the corners of the device. Minimal bumpers would serve without adding much to size (perhaps a bump could be added to protect the camera lens too).
I’ve not printed with this kind of precision before. Can a softer bumpier filament (green) be used, so that it would merge with a harder filament (orange). I could try to do this with as craft project before printing. To make a proof of concept.
I thought the idea of a bumper case is that the back gets heavy enough that it is most likely to drop on it instead of the front. In some cases (pun intended) there is also a little raise on the front to protect for a screen down flat hit, which would be helpful, but a bit hindering with SFOS gestures.
Generally a good idea though in my opinion. I was always a fan of bumper cases. Though they dont need to be that thick to protect against drops i think (see Rhinoshield).
I think the point of having the bumpers to the screen side only at the corners is exactly not to hinder the SFOS gestures
yeah i know, but even with just having them at the top screen corners it would hinder the closing an app gesture
Yes, this would be like a skeleton bumper, with only minimally leaning over the front in the corners. The only gesture effected would be slide to close, and the skeleton bump can be designed small enough to accommodate.
A “little raise” mentioned by @JE281 would protect the glass. Any ideas on how thick it should be? 2mm?
I’d also like to see it protect the back camera lens and so it can lay flat…
Laying flat would be awsome, but i don’t think the cameras have to be protected separately
Yeah, the case flattening the back would protect the cameras more, not to mention make the phone not wobble on the desk and in phone holders which honestly should be an option even for the normal back covers.
A lens bumper would not require a lot, it could made to a shape which also adds some grip to the back. Lifting then edge of the lens (like 1 mm from a flat surface).
Concerning the corner bumpers, I’m thinking it would be economic to make prototypes as detachables which could secured to an existing cover. It might even work better then making a print (because injection moulded TOHs might have more bend to transfer the impact).
Here is a polymer-clay mockup. I’ll try to make the design so that the same shape can be rotated for every corned (only the bottom bumps need extra work to open the speaker and maker room for SIM/SD-card).
I’ll investigate a good bouncy but robust substance, I could use for casting this for a prototype. There is 2mm of clearance (in case it would fall face flat) for the screen and 1mm for the camera lens to keep it from scratching.
Which also may finally stop the phone from wobbling around when placed on a flat surface. :laughing:
