You can install both, but one will overwrite others bridge and qml module. I had to modify bridge to increase burst images from 8 to 16 for night mode. I will move it to a different path so people can use both.
Impressing!
I like the rainbow + light flair. Makes the pic alive, imho.
I saw you even use 16 RAW pics for the night mode.
And also, using the GPU, that’s cool, really next next gen.
I’ve got to try, along with RAWfish, to see the differences in the night stacking modes.
Hey, it works perfect on xperia 10 III with 5.1.0.11. It is possible to add a camera choose for all 3 cameras from x10III please? In the moment I can only choose 2 cameras and the portrai camera.
You got it working on an 10 III with 5.1 ??? I wonder why it didn’t work for me? Maybe I had the rawfish install still there, after all? Hmmmm. It’s difficult to test all these camera2 apps
EDIT: I made sure all the rawfish installed files were gone. Photos do not get assembled. Video recording works. Rawfish works for photos.
@poetaster could you provide please Pictures/ProCam/procam-capture.log and also ProCam_20261102_…json for photo you were trying to take? This might give me more information, why it is failing for you.
Very interesting app, thanks for making this available.
On my community port Volla Quintus the preview is not available and says ‘libprocamcamera2.so’ not found when trying to capture a shot.
That is great news. Both apps are sufficiently different to coexist and therefore it is good news that they can now coexist.
Even though these are two forks now, it would be great if improvements relevant for both could be exchanged in the spirit of cooperation back and forth.
ProCam only allows bursts when the camera reports all four of these:
that apps can set ISO and shutter time per frame
that the camera is certified for full manual control
that it reports back the actual exposure of each frame
that it has a usable RAW size
One of them is false on this Xperia. My guess is that the camera allows manual ISO and shutter but doesn’t claim the full manual-control certification. If so, a small relaxation of that check would turn bursts on.
You have right only video is working the camera mode give this false “Camera2 warm capture failed”. With v1.4.0-beta.1-1, v1.4.0-beta.2-1 and v1.4.0-beta.3-1…
Now it runs, the main problem was I had to create the Folder “ProCam” manual under /home/defaultuser/Pictures/. After it the app work and saved .jpg, .json, .raw16 and the .log in this folder. I the folder Video the files are saved in the Folder Camera and there exist from the native app. procam-capture.log.targz (14.8 KB)
