Emma keeps saying that device is locked despite I have turned on the OEM unlocking from developer tools. Checking the settings in the phone shows unlocking is allowed.
Also if I try to unlock it with fastboot on Linux, adb does not even recognize the device.
Does it still matter which USB port (2 or 3) must use?
Flashing a device (I did often meanwhile) on Ubuntu Linux for me never worked as user, always had to enter the flash command beginning with ‘sudo’ and enter root password after pressing ENTER.
Oh it was supposed to be the blue light and not green? Now I tried again and by running unlock command with sudo it did not give any error, but light turned to red and terminal printed <waiting for device>
Still in Emma it says its locked
Yes. As I stated earlier, I noticed that I was pressing the wrong button, and after that I was able to enter the unlock oem command in fastboot without error, but it did not help.
