Problem with USB DAC playback
EDIT: on JollaPhone-2026 pactl set-sink-volume fix does not work as the DAC is not separate sink anymore but it is just port of default sink, anyway there is another way via alsamixer as described bellow.
On the Xperia10V or any other phone running SF up to 5.1.0.x:
create symlink if not exist (it does exist on 10ii by default so no need this step there):
with root perms (devel-su):
ln -s /etc/pulse/xpolicy.conf.d/usbaudio.conf.disabled /etc/pulse/xpolicy.conf.d/usbaudio.conf
as defaultuser: systemctl --user restart pulseaudio.service
You will need nano (pkcon install nano) or any other editor …
A) Automatic (not only) Apple DAC silent volume fix after plug
Only for Jolla Phone 2026 (or perhaps all since SF 5.2): install alsa-utils - skip this step on SF5.1!
zypper install alsa-utils
On all versions:
devel-su nano /usr/local/bin/set-usb-dac-volume.sh
on SF5.1.x.x paste following:
#!/bin/sh
# !!! update sink name to yours - it contains unique serial number !!! `pactl list sinks|grep Name`
# someone could improve this to autotdetec script
sleep 2
pactl set-sink-volume alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH504202DRL1MQAF-00.analog-stereo 100%
for Apple DAC on the Jolla Phone 2026 (or all SF5.2+ devices) paste following:
#!/bin/sh
sleep 2
amixer -c 1 sset Headphone 100%
for other DACs you need to get mixer control name: amixer -c 1 on the first line is name what you will type into your set-usb-dac-volume.sh script
for Axagon Hi-Res DAC on the Jolla Phone 2026 (or all SF5.2+ devices) paste following:
#!/bin/sh
sleep 2
amixer -c 1 sset Speaker 100%
devel-su chmod +x /usr/local/bin/set-usb-dac-volume.sh
rest of steps are same for SF 5.1 and SF5.2…
devel-su nano /usr/local/bin/udev-create-flag
#!/bin/sh
# called by udev (runs as root)
# write a flag in the user's runtime dir so the user service notices it
USER="defaultuser"
FLAG="/run/user/$(id -u "$USER")/usb-dac-connected.flag"
mkdir -p "$(dirname "$FLAG")"
touch "$FLAG"
devel-su chmod +x /usr/local/bin/udev-create-flag
devel-su nano /etc/udev/rules.d/99-usb-dac-volume.rules
ACTION=="add", SUBSYSTEM=="sound", RUN+="/usr/local/bin/udev-create-flag"
ACTION=="change", SUBSYSTEM=="sound", RUN+="/usr/local/bin/udev-create-flag"
nano /home/defaultuser/.config/systemd/user/usb-dac-volume.path
[Unit]
Description=Watch for USB DAC flag
[Path]
PathExists=/run/user/%U/usb-dac-connected.flag
Unit=usb-dac-volume.service
[Install]
WantedBy=default.target
nano /home/defaultuser/.config/systemd/user/usb-dac-volume.service
[Unit]
Description=Run USB DAC volume script when flag present
After=default.target
[Service]
Type=oneshot
Environment=XDG_RUNTIME_DIR=%t
ExecStart=/usr/local/bin/set-usb-dac-volume.sh
ExecStartPost=/bin/rm -f /run/user/%U/usb-dac-connected.flag
TimeoutStartSec=60
[Install]
as root:
devel-su udevadm control --reload
now run as the defaultuser,
Reload user units:
systemctl --user daemon-reload
Enable and start the path unit so it watches for the flag:
systemctl --user enable --now usb-dac-volume.path
now it works perfectly, i just plug Apple USB-C to 3.5"Jack (Part number: MW2Q3ZM/A)
music is instantly routed to headphones and in two seconds the volume is without limit and then could be adjusted in UI/buttons 0% <=> true 100% like it is expected.
B) Manual (not only) Apple DAC silent volume fix by app launcher
create file /usr/local/bin/set-usb-dac-volume.sh as described in (A) automatic method and make it executable
create desktop entry:
nano /home/defaultuser/.local/share/applications/usb-dac-fix.desktop
[Desktop Entry]
Type=Application
Name=Apple DAC fix
Exec=/usr/local/bin/set-usb-dac-volume.sh
Icon=icon-m-browser-sound
[X-Sailjail]
Sandboxing=Disabled
Interesting. You do not need
pactl load-module module-udev-detect
no it looks like it is loaded by default
pactl list modules |grep udev
	Argument: device_id="1" name="usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH504202DRL1MQAF-00" card_name="alsa_card.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH504202DRL1MQAF-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
from /etc/pulse/default.pa
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
yeah, I know it’s there. It just doesn’t work on the volla phones. But, I’ve adapted your approach to use pactl so that it works to pactl load instead of volume since the adapter I’m using does not require setting the volume. Thanks :slight_smile:
EDIT: on the xperia 10iii I also have to force
Ooof. Sadly, I can no longer use the telephone, freezes. :frowning: Need to roll back and start again.
EDIT: @koza technique worked on the volla22 / rephone, BUT caused the phone app to freeze. Manually loading the module is fine. When a call comes in the usb-audio stop (and media player, for instance) and calls work normaly. On the experia 10iii The same technique doesn’t work for me, but manually starting (using the same script systemd is supposed to run) works. Hmmmm.
for the Apple dac the volume fix works perfectly, no issues with anything.
i think that module-udev-detect should be loaded before you plug dac to usb port otherwise perhaps loading after plug may confuse/hang pulseaudio and then phone app or maybe even media player will freeze too
i dont have 10iii but 10ii loading module-udev-detect automaticlaly without tweaking system, there is /etc/pulse/xpolicy.conf.d/usbaudio.conf
all on SFOS 5.0.0.72
Oh by the way if you guys want better sound quality for music, because Jolla is all about legacy and still uses garbage tier resampler because jolla phone 1 couldn’t handle better one (we got much better cpus since then) then i recommend my blog post Audiophile ways on SailfishOS
At user defaultuser the command returns an error.
Running pactl list shows the module loaded already (on my fp4 with SailfishOS)
defaultuser@fp4-1:~ $ pactl list
Module #2Name: module-udev-detect
Argument:
Usage counter: n/a
Properties:
module.author = “Lennart Poettering”
module.description = “Detect available audio hardware and load matching drivers”
module.version = “14.2+git9”
But i don’t get the Fairphone USB DAC working …:thinking:
Did you enable /etc/pulse/xpolicy.conf.d/usbaudio.conf
and add a udev rule? The one suggested by Jolla requires a hardcoded card id. I the one I posted does not:
echo 'ATTRS{id}=="mtsndcard", ENV{PULSE_IGNORE}="1"' > /etc/udev/rules.d/89-pulseaudio-usb.rules
I’d reboot, though you could in theory just reload udev.
I enabled the usbaudio.conf and created the 89-pulseaudio-usb.rules as described above.
After rebooting the device it works as expected :slightly_smiling_face:.
Many thanks
This works for Fairpbone 5 as well. Nice since neither have headphone jacks.
This setup works now, but must never be used in front of a wife or girlfriend.
And maybe we should let @mal know about this. So I guess I did…
Did you really need that udev-rule? Fairphones should have functioning udev rule already, just the usbaudio.conf symlink is missing, I don’t have any USB DAC so I don’t have any way to test it and I missed that earlier. I’ll also check other devices what those are missing.
@mal you are right. The udev rule is not requiriert on the SailfishOS for fp4 (and the same on fp5 i think :wink:). Many thanks for your support.
buy the apple dongle :smiley: Inexpensive and good enough for testing :stuck_out_tongue:
Same for the fairphone usb-audio adapter whitch i use Adapter USB-C-Audioklinke (3,5 mm) | Fairphone … :wink:
Yes, likewise on FP5. I rechecked without the udev rule. Copying/renaming/linking usbaudio.conf was the only change necessary and it was sufficient to play audio through my USB DAC. :slight_smile:
These wiki instructions made my Fiio KA11 USB DAC work on the Xperia 10 V with 5.0.0.72 !!
I wanted to point out that playing with the udev rules and loading modules SHOULD, if you can, be avoided :slight_smile: In my case, dynamically forcing pactl to load the pulse module works but kills incoming phone calls :frowning: It’s good to hear that the fp4/5 devices have functioning rules. Could someone post what those udev rules are? @mal ? I’ll update the wiki …
Which device are you using? The udev rules are device specific.
I’m using a volla 22 and an xperial 10iii. The default rules on the volla don’t include any like the recommended (from the usbaudio.conf)
KERNEL=="<CARD-HERE>", SUBSYSTEM=="sound", ATTR{id}=="<DEVICE-ID-HERE>", ENV{PULSE_IGNORE}="1"
The rule
from the oesf.org forum entry, works on both xperia and volla phones.
One or two things to be said about that blog post:
  1. If the audio you are playing was sampled produced at 16 bits there is NO point in doing 24/32 bit output
  2. If the audio was sampled at 48kHz, there is NO point in changing the sample rate.
As it stands, relatively little music is distributed (flac or otherwise) at more than more than 16 bits for playback. For internal processing 24/32 bits is standard at rates of up to 192kHz (though 98 is more common). So, it’s a waste of processing power unless you know you have high resolution data.
The apple dongle (and a couple of others I’ve now tested) all support 48kHz and 24 bits, which works for me, but the fact is, I don’t record most material at 24 bits. In any case, the libsoxr advice on that blog page is good and it will help, though, just using a usb dac makes a big difference.
