Problem with changing the call forwarding settings
REPRODUCIBILITY: 0% (not specified)
OSVERSION: 5.0.0.71
HARDWARE: Jolla C2 - s19mps - s19mps - 1.0.0.52 - aarch64
REGRESSION: not specified
Device can’t recognize call forwarding is on and device can’t change settings.
I don’t understand this point.
  1. Device retrieves settings couple minutes before settings page is opened
  2. When changing settings device reports: “Problem with changing the call forwarding settings”
  3. Device turned call forwarding on but it didn’t report that.
  4. Device can’t change settings or turn call forwarding off - even I reboot phone.
EXPECTED RESULTS:
Call forwarding is switched on/off
ACTUAL RESULTS:
Call forwarding has been stuck. Can’t switch off.
  • Patchmanager: yes
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.16+git2
Earlier reports/discussion/duplicates:
Note: Most of these problems are reported fixed. But the discussions might be useful on how to get and read logs.
Thanks for reporting the issue. I’ve created an internal bug report about this.
How does call forwarding work? I didn’t even know we could do it with SailfishOS?
Settings → Apps → Phone app
Call forwarding was indeed broken and made a fix for it Fix call forwarding, setting data profiles and 5g in AIDL interface. Limit default preferred network mode by available technologies by mlehtima · Pull Request #47 · mer-hybris/ofono-binder-plugin · GitHub and fixed some other issues at the same time
I have to say I don’t understand this (I’m very bad with code things). Is this kind of guide for users or something else?
So I just did a test with forwarding all my call my X10 III SFOS 5.0.0.72 and the error came up -
problem with changing the call forwarding settings
but the actual forwarding was done.
I think this would be “something else”, i.e. the developers have found the reason for the incorrect behaviour of the device and also already developed a fix. Right now, I think there’s nothing for us basic users to do except to wait for the fix to be released in a future software update.
Thank you for this answer
