My phone went locked state in my pocket. I tried to unlock it. The problem is :
 Jolla Recovery v2.0
Welcome to the recovery tool!
The available options are:
- Reset device to factory state
 - Reboot device
 - Shell
 - Perform file system check
 - Run sshd
 - Exit
Type the number of the desired action and press [Enter]:
3
If you continue, this may void your warranty. Are you really SURE? [y/N] [y/N] Y
/dev/mmcblk0rpmb: read failed after 0 of 4096 at 0: Input/output error
/dev/mmcblk0rpmb: read failed after 0 of 4096 at 4128768: Input/output error
/dev/mmcblk0rpmb: read failed after 0 of 4096 at 4186112: Input/output error
/dev/mmcblk0rpmb: read failed after 0 of 4096 at 4096: Input/output error
2 logical volume(s) in volume group “sailfish” now active
Fri Oct  9 14:01:46 UTC 2020
WARNING: Locking directory /run/cryptsetup is missing!
Type your devicelock code and press [ENTER] key:
(please note that the typed numbers won’t be shown for security reasons)
[WARNING] Wrong code, try again (4 left)
I can not to give the command :
chroot /rootfs
/usr/lib/qt5/plugins/devicelock/encsfa-fpd --check-code xxxxx
I pulled out the USB datacable, and few seconds later connected again.
root@debian8kde:/home/vlad/Xperia/Sailfish_OS-Jolla-3.3.0.16-f5121-0.2.1.25# telnet 10.42.66.66
Trying 10.42.66.66…
Connected to 10.42.66.66.
Escape character is ‘^]’.
Sorry too many failed lockcode attempts.
And it has not been 24 hours since last attempt.
Connection closed by foreign host.
I know my lockcode…
And now, I have only one chance to do something (get the correct lockcode).
The question is : simply copy/paste these commands above?
Another question is :
The phone now show me “RECOVERY: connect USB cable …”
Is possible to switch off the phone or need to wait 24 hours?
Best regards : -=L=-
