Power consumption oft Sony Xperia 10
I use a Sony Xperia 10 (Dual Sim) and wonder a bit about the power consumption.
One hour of surfing requires about 15% to 20% battery capacity. And I only read manuals or similar. The screen is set relatively dark and dims completely after a minute of idle. Is this normal?
A Nokia with an almost equally large battery lasts much longer under Android.
How does it look with other Sony smartphones under SFOS?
IME, Wifi draws a lot of power in X10.
And depending on which sites you visit, the Browser can use a lot of resources too.
Search the forum, and e.g. this thread for some similar experiences, and possible solutions:
