Possibility to only allow incoming calls from registered contacts
Hey,
A minor request :slight_smile:
I’m not sure if this one has been requested before. On my old phone, I had the possibility to only loop incoming calls through, whom I already have in my contacts. All other calls from unknown and numbers not in my contacts will be muted.
I know that it could be similar to Call Blocking features, but since I basically don’t expect incoming calls from numbers I don’t know, I won’t be disturbed during the day by incoming calls I’m not interested in.
/Yngve
This is already kind of available, enable Do Not Disturb mode in Sounds & feedback. Not exactly what you want, but maybe a stop-gap?
Yeah, I saw that was possible, unfortunately DnD will silence incoming text messages from all :-/
From what I read, it’s possible to selectively block specific numbers (i.e. a block list), but no mention of an allow list.
It looks like you can block anonymous/hidden numbers, which are most likely to be spam:
Regarding other numbers, since there is talk of incoming calls being recorded to a log, it might be possible for a program to watch that log for a new incoming call, check it against your contact list, and if not recognised then add it to the block list. (Not sure if this would block the current incoming call, or just future calls from that number.)
Someone could probably use the source code of the following program as a basis for what you want:
(It blocks all numbers from some public list.)
