Recently, I have been having a problem with Magic Earth, under 4.5.0.19, with the official Jolla Android Support.
After getting the first location fix, the GPS position does not update while I move but stays stuck in the same location as when I first opened the app.
The location updates correctly in other Android apps, e.g., maps.google.com under Firefox / Fennec.
It seems to me that the problem started when I updated MicroG to 0.2.28, which includes an overhaul of the location stack. Unfortunately I cannot fix this by downgrading; when I try downgrading to 0.2.27 using F-Droid I encounter an error.
Does anyone have the same problem, or similar ones? Do you have any suggestions to diagnose the cause or fix the problem? Thanks!
