[Portuguese Brazil] Translation coordinator
Is there a coordinator for Portuguese (Brazil)? MarcosAM seems to be unavailable.
If there is a need for an additional person, I can do it.
ping @caio2k
@pherjung if you login at translate.sailfishos.org I can add the coordinator permissions for you. All help is really appreciated.
Portuguese translation is almost finish. If someone could check Translate | Portuguese (Brazil) | Sailfish OS Localisation I’ll be grateful.
