Seems like from yesterday update my phone can act dead (charging while turned off)
Everybody keeps telling me it’s how it should be but but i don’t think it is as now phone even has troubles powering on
If i press the power button it vibrate for a brief second, and then nothing happens
I need to plug the charger so the phone can act dead and while the battery indicator is on, turn it on with the usual power button, only this way the phone will power on
The “act dead” mode, .i.e. start the minimal charging mode when device is off and it is plugged into usb power, has been there always, it is nothing new in the latest update.
However, if the device does not start without being plugged in, then there is something wrong.
Does it show the Sony logo and unlocked bootloader warning when you try to turn it on, or just vibrate with black screen?
The bootloader version depends on what Android version was on the device before flashing Sailfish. Apparently the LA3.0_P_38 handles the boot to charging/act dead mode differently.
