REPRODUCIBILITY:-
BUILD ID = OS VERSION:3.4.0.22+24
HARDWARE:-
UI LANGUAGE:na
REGRESSION:?
Menu item “Save as contact” is not shown when long tapping on a number in call history.
“quick call” is off
- switch off “quick call”
- long tap on number in history of phone ui
long tapping on number always shows “Save as contact”
“Save as contact” is missing
In “/usr/share/voicecall-ui-jolla/pages/CallHistoryView.qml” there is on line 234 “visible: !privateNumber && quickCall”. Why is that? Removing “&& quickCall” and restarting Homescreen does the trick. However, didn’t check for side effects.
I agree that this way it would be better.
However, you can do it in the following way, instead, as “Quick call” is OFF:
- Tap the number in call history.
- Pull down “Save”.
- Edit: add name and details.
- Tap Accept.
In other words, it works. But the UI is perhaps not consistent.
I figured that. Do you really want me to explain that to my wife?
I haven’t seen any illeffects till now…
Thanks for answering.
So, I have been using this:
— CallHistoryView-4.1.0.24.qml 2021-06-24 12:23:50.536749786 +0100
+++ CallHistoryView-mar-4.1.0.24.qml 2021-06-24 12:28:08.663214666 +0100
@@ -226,7 +226,8 @@
MenuItem {
- visible: !privateNumber && quickCall
+ //% visible: !privateNumber && quickCall
+ visible: !privateNumber
objectName: “contactCardMenuItem”
text: {
//% “Open contact card”
… on
PS: don't know how to get it properly formated...
