Phone calls not silenced by power button anymore
REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.77
HARDWARE: Sony Xperia 10 II - Dual SIM
UI LANGUAGE: German
REGRESSION: Yes
After the update to SFOS 5.0.0.77 the power button does not silence any incomming phone call anymore.
I updated my device from SFOS 5.0.0.68.
  • The ringtone is silenced (just vibration)
  • The phone’s vibration is turned on
  • The Do not disturb mode is disabled
  1. Receive a phone call
  2. Press the power button
The phone stops to vibrate
The phone still vibrates as long as the phone call was not canceled/taken
None
Nothing to add here
I know that when I press the mute button during a call, both the sound and the vibration stop—if I’m not mistaken
Why you don’t turn phone upside down, calling stops immediately. It is available settings > gestures > Flip to silence calls and alarms.
This does not work either, this feature seems to be broken too.
Also the usage of another feature is not the solution for an existing regression. :confused:
Is Do Not Disturb enabled? And silence mode? Please answer by editing your bug report
