Phone app. Recorded calls in pulley menu
Finding the ‘recorded calls’ list seems only to be by following these steps :~ System, Apps, Phone, and then Recorded calls.
Would it possible to add Recorded Calls to the Pulley Menu under History in the Phone app ?
If so, then the historical recorded calls would be located far more easily.
I would also like to have an option to auto-delete recordings older than x days. And some way to export the call recordings. Could probably solve it with some scripting, but I’d prefer a built-in way.
I had no idea you could record calls, awesome!
