Xperia 10
Telephone app does not launch. I can’t make or receive calls. I just updated to 4.3.0.12. The update froze and I had to reset the phone. Most things seem to work but maybe the failed update broke the phone app. Should I try to manually reinstall it or is there something else I can do?
Maybe installing sfos-upgrade from storeman and reissuing the upgrade could help.
sfos-upgrade | OpenRepos.net — Community Repository System (you can also download the rpm and install it directly to avoid installing Storeman)
First I’d do a
ssu re
ssu lr
and check all the versions match up.
Then
pkcon refresh
pkcon update
See if it wants to install something new.
