Hello i have permanently locked my phone(device lock)
phone xperia 10 III latest update. laptop windows 11.
I have done required steps get to the recovery mode but in the cmd/powershell phase when i type telnet 10.42.66.66. Screen is empty and when i push any button it goes back normal.
I have installed sony sa0114 driver i have enabled windows telnet. i dont know if i have to install rndis driver or how to do that.Tried with diffrent usb cabels same outcome. blue led.This is what i am after Releasing Xperia from âPermanent lockâ 3) Shellâ in the Recovery menu
Thank you.
Have you flashed the recovery image on your phone using fastboot? If you have flashed the recovery image you boot the phone up normal and can telnet into it.
I tried it now hereâs the result
Sending âboot.imgâ (30848 KB) OKAY [ 0.992s]
Booting FAILED (remote: âunknown commandâ)
fastboot: error: Command failed
Are you following this guide?
yes got to the recovery mode now and in the shell it ask device lock code. I have 2 tries left. My question is this i tried the device lock code but it said wrong code. but in the documents it says like so 3) Shellâ in the Recovery menu Type the following two commands. In the latter command, replace â12345â with your correct security code!
chroot /rootfs
/usr/lib*/qt5/plugins/devicelock/encsfa-fpd --check-code 12345
exit
Do i type the text with code replaced with my owncode?
There was a time when spaces in passwords didnât work in recovery mode although they were working in the graphical password interface.
Not sure if it is still of actualityâŚ
Do you have a space in your password?
no it asked the code but in the guide there are text do i have type text also?
Iâm sorry, I donât know this procedure. I canât answer.
I managed to unlock the phone with your help thank you.
Glad you got this sorted, but for future reference, you have to first enter your device lock code in order to enter the actual Shell and after you get into the shell, you type/copy&paste the commands you listed. After that, you follow the guide to restore the proper boot image and your new lock code is 12345 or what ever you used instead of that.
Any guides available for J2 phone? The above guide is only for Xperia devices. My pocket apparently has tried to open my phone too many times, causing the phone to permanently lock the device
Power off the device, press and hold VolUP + Power until you see Jolla logo. Select recovery shell.
Yeah. For some reason I thought it was volume down! Vol up + power worked, and telnetting + chroot and the command worked
Personally I de-activated the maximum attempts in the Settings. It is more likely that the maximum attempts will be reached in a pocket accident than by a motivated thief. And there is not much a point if the thief can also go to recovery mode and get more attempts from CLI.
