People. Address loss
OSVERSION: 4.6.0.15
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.1.14 - aarch64
REGRESSION: yes (since: n/a - n/a)
Adding an address with edit function results in loss of all addresses except the last one entered.
Noticed on X10iii some time/ unknown updates ago.
1.people, add contact.
2.enter details including one or more addresses… Then accept…
3.Edit, add address, insert another address then accept.
EXPECTED RESULTS:
All addesses to be visible.
ACTUAL RESULTS:
All but the last entered address disap
ears.
  • Patchmanager: no
  • OpenRepos: no
  • Chum: yes
  • Other: none specified
C2 with 5.0.0.29 appears ok, no bug.
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.11+git2
Could not reproduce (only tried once) on XIII with SFOS 4.5.0.24.
Just to confirm the negative:
Can not reproduce on C2 (with a Phone contact).
Do you sync with a cloud service?
If others can’t reproduce, that could be a differentiating factor.
Hi, thanks for the tip, my backups go onedrive ok so i guess i’m sync’d or?
Now resolved, settings,accounts,google… Contacts,sync… Changed from ‘two-way’ to ‘to device only’.
Then able to edit and add addresses and accept without loss.
