I’ve fixed launcher combined by Coderus and folders with small icons works perfectly. You can try rpm file if you want from here: https://github.com/carmenfdezb/patch_launcher_combined/releases/download/1.0.0-1/launcher-combined-1.0.0-1.noarch.rpm
I’ve tried to upload patch to web catalog but for some reason files are missing. Maybe @olf can help me?
What file are you trying to upload, and what errors do you get from Web Catalog?
Hello - I installed the rpm from filrmanager and after I deactivate the fork path and activate this path it works fine now. A big Thank You fore your work!!!
It seems that I can’t upload any files from web catalog with my profile since yesterday, I don’t know if others users have the same issue.
Kuba77
10 August 2022 09:12
170
Try to use zip instead of tar.gz
