Patch: Calendar events on lockscreen
This is a patch for the lockscreen to show the upcoming events on the lockscreen. The view is fully configurable using the settings.
i just updated patch to work on 5.0.0.55 and it is available to install via PatchManager Web Catalog
you must uninstall previously installed rpm from Patch: Calendar events on lockscreen | OpenRepos.net — Community Repository System
version 1.2.0
more optimized for 5.0.0.55
note: if original author will publish updated version i will delete my release
Thanks for publishing this as a temporary solution. I missed this thread and didn’t know the patch wasn’t working until I updated my phone to v5 last month. I’m going to release my updated version on open repos with landscape support and an extra option to move the clock around.
great :+1: btw in the landscape mode dont forget to check when media widget and call in progress is there :slight_smile:
This patch works well but conflicts with the launcher combined patch so that launcher no longer works. I tried deactivating and reactivating and when that didn’t work I just removed the calendar event patch. Maybe with some experimenting they could work together.
Fully working patch uploaded onto open repos now. It allows you to move position of clock, media controls and ongoing call.
Which version of launcher combined patch are you using? I tried the fork by carmenfdezb and it works with no conflict.
I reinstalled calendar events just now and everything works as expected, same Launcher Combined fork.
