Two questions:
First one is not only related to Parrotfish. Why is Text prediction in Browser disabled.
I have the feeling learning new words doesn’t work. How often has a word to be typed ti be added to the dictonary?
Apart from that, great work!
Two questions:
Thanks for the feedback! Regarding your questions:
FYI I released Parrotfish 1.2.0 with Emoji support among other improvements and fixes:
For the full changelog see Release Parrotfish Keyboard 1.2.0 · ccontino84/parrotfish-keyboard · GitHub
You might consider splitting out the language packs into a separate repo. As it is, you can’t install with harpoon to get all the packages. Or maybe there is an idea from @Lehtimaeki
Thanx, for your detailed answers.
I feared that it is like that. For me this is a bit annoying. As I often write in forums and have no support there. I think I will try to address this to @Jolla team. Maybe via a bug report.
Ok, that’s really very conservative. Especially the 5.000 words thing. I NEVER write 5.000 words in a session on a smartphone. But I agree that there should be some safety implementation to avoid that every typo is learned.
If it should stay more conservative maybe it would make sense, that people can add words manually.
No sorry if I didn’t clarify that:
the word has to appear in 3 different texts within 5000 words typed in that language
after you write 5000 words without typing it, the count starts over from zero
It’s to avoid that you learn a word that you type 3 times in your whole life.
I didn’t know about Harpoon, but I think it’s more a problem with the package names. Should be fixable with the single repo approach.
That would be cool. Since I hack my keyboards, parrotfish is probably not for me, but it’d be nice to try it ![]()
Luckily today I have a day off, so I just clauded it. Can you try again with 1.2.1?
Hmmm. Still no languages installed.
Too bad, let’s see if @Lehtimaeki has an idea about that
I think he just installs the first rpm matching the name and release/arch pattern.
Seems to be related to Issue with two packages, this time with different names · Issue #8 · JuhaniLehtimaeki/Harpoon · GitHub I added a comment there
Seriously solid improvement with 1.2.0.
I also switched to your keyboard full time now. Thank you for the great work.
Sorry I got you completely wrong. Now I understand, and I think that might be conservative, but it’s absolutely fine. It just takes a bit longer until words are trained. But that’s for sure better than having thousands of misspelled words in the wordlist.
Thank you for clarification.
Hi, experienced little issue with latest version. After switching orientation to landscape and back keyboard size didn’t restore correctly.
Adjustin the the size fixed it to original size. Someone else too?
I took a look at the ticket, but one thing occurs to me. This is putting the onus of parsing many variable types of package releases on a very straightforward app. IE, it pulls a release for an arch of a single package. In my opinion this should be dealt with by either including the data in the main package, or having a separate repo for it. The way this is dealt with in build systems like chum (obs) is well know and well tested and it uses dependencies available within the system to resolve how to find stuff. You can’t expect that from harpoon. It’s asking too much.
I can’t imagine the data required for parrotfish is so large that it couldn’t just be included?
It’s a real regression, it happens when you set landscape and portrait at the same size. The workaround is to set different values until I have a proper fix.
Thx, it works great so far. But I do miss Slovenian layout as three quite common letters (čšž) are hidden behind long tap. SFOS original has a proper one. Or native FUTO.
I really hate layout mangling by the big two. It not only ruins typing for at least our language but it also distort the language.
Fun example:
What about moving the many layouts on Parrotfish Settings page? As I’m pretty sure there are many other nonASCI typers. Most of the European languages actually.
Ok, took me half a day recognize that emojis are there
Boah, this is so great and convinient. Thx for that… Now don’t have to switch the keyboard
