Sorry to announce but android apps ParkMan and Aimo park does not work amymore. “Your phone does not support Google services”.
C2, 5.2.0.22 + microG.
Without any other changes on your phone?
I have no way to test it. Is it possible that ParkMan and Aimo Park are restricted to Norway? Can you share some links?
Edit: Using a free VPN did the job, but I still don’t find an app called ParkMan and I have no possibility to verify Aimo as you need an account…
No changes made to the phone. I have not used those apps for a while
Lers say two weeks or so. They where recently updated an I assume the problem started after that.
Cannot say if they are restricted in Norway. Park Man is Finish (I guess) and Aimo park is Swedish.
ParkMan uses Google maps and I think so does Aimo park.
PS. I try the older versions if I finf version numbers.
Do you have the latest microG (by enabling their repo on fdroid) or not?
Easypark is working (in Finland) except location. But if you zoom to the right location the app shows the parking areas.
Yes I have the latest version of microG from Fdroid.
Hmm…l had unchecked from microG settings the System Spoof Signature. Thats why the maps did not show up😄. I unchecked it because when I start Aimopark it opens the microG self check window instead.
So problem solved partially.
I’m wondering if is it a C2 too?
Aimo Park works well for me in Sweden, on my Sony Xperia 10 II with SFOS 5.2.0.22.
Maybe not fully relevant to the topic, but Parkman 7.0.0 (409) seems to work properly on Jolla Phone 5.2.0.22.
Thanks. Tried to downloas and install that version but got an errormessage. I try later again…
