Pageheader: Title. Multiline problem
Hi
In my qml code, I have the following snippet:
PageHeader {
title: someTitleFromVariable
This works fine. The variable ‘someTitleFromVariable’ was always filled as string from external source. Now one case came up when this variable contains a lot of text with also multiple lines. This renders the whole page useless.
Question: Is it possible to force this string to be displayed only as one line and just skip the rest of the (long) string? I did not found anything in the documentation of that element.
Best regards
Geobra
Maybe try modifying the component itself by adding a maximum line count like below, need to save this as a .qml file (eg: PageHeaderCustom) then change PageHeader to PageHeaderCustom (untested I have no device near me ):
** Copyright (C) 2013 Jolla Ltd.
** Contact: Joona Petrell <joona.petrell@jollamobile.com>
** All rights reserved.
** This file is part of Sailfish Silica UI component package.
** You may use this file under the terms of BSD license as follows:
** Redistribution and use in source and binary forms, with or without
** modification, are permitted provided that the following conditions are met:
**     * Redistributions of source code must retain the above copyright
**       notice, this list of conditions and the following disclaimer.
**     * Redistributions in binary form must reproduce the above copyright
**       notice, this list of conditions and the following disclaimer in the
**       documentation and/or other materials provided with the distribution.
**     * Neither the name of the Jolla Ltd nor the
**       names of its contributors may be used to endorse or promote products
**       derived from this software without specific prior written permission.
** THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
** ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
** WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
** DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDERS OR CONTRIBUTORS BE LIABLE FOR
** ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
** (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
** LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
** ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
** (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
** SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
import QtQuick 2.6
import Sailfish.Silica 1.0
import "private/Util.js" as Util
SilicaControl {
property alias title: headerText.text
property alias _titleItem: headerText
property alias wrapMode: headerText.wrapMode
property alias extraContent: extraContentPlaceholder
property string description
property int descriptionWrapMode: Text.NoWrap
property Item page
property alias titleColor: headerText.color
property real leftMargin: Theme.horizontalPageMargin
property real rightMargin: Theme.horizontalPageMargin
property real descriptionRightMargin: rightMargin
property bool interactive: enabled && page && page.canNavigateForward
readonly property bool defaultHighlighted: interactive
                                           && ((_navigateForwardMouseArea && _navigateForwardMouseArea.containsMouse)
                                               || (pageStack._pageStackIndicator && pageStack._pageStackIndicator.forwardIndicatorDown))
property Item _descriptionLabel
property real _preferredHeight: page && page.isLandscape ? Theme.itemSizeSmall : Theme.itemSizeLarge
onDescriptionChanged: {
    if (description.length > 0 && !_descriptionLabel) {
        var component = Qt.createComponent(Qt.resolvedUrl("private/PageHeaderDescription.qml"))
        if (component.status === Component.Ready) {
            _descriptionLabel = component.createObject(pageHeader,
                { "wrapMode": Qt.binding(function() { return pageHeader.descriptionWrapMode }) })
        } else {
            console.warn("PageHeaderDescription.qml instantiation failed " + component.errorString())
property Item _navigateForwardMouseArea
onInteractiveChanged: {
    if (interactive && !_navigateForwardMouseArea) {
        var component = Qt.createComponent(Qt.resolvedUrl("private/PageHeaderMouseArea.qml"))
            _navigateForwardMouseArea = component.createObject(pageHeader)
        } else {
            console.warn("PageHeaderMouseArea.qml instantiation failed " + component.errorString())
Component.onCompleted: {
    if (!page) {
        page = Util.findPage(pageHeader)
width: parent ? parent.width : Screen.width
// set height that keeps the first line of text aligned with the page indicator
height: Math.max(_preferredHeight, headerText.y + headerText.height + ((_descriptionLabel && description.length > 0) ? _descriptionLabel.height : 0) + Theme.paddingMedium)
highlighted: defaultHighlighted
Label {
    // Don't allow the label to extend over the page stack indicator
    maximumLineCount: 1
    width: Math.min(implicitWidth, parent.width - leftMargin - rightMargin)
    truncationMode: TruncationMode.Fade
    // color should indicate if interactive
    color: interactive
           ? (highlighted ? palette.highlightColor : palette.primaryColor)
           : (highlighted ? palette.primaryColor : palette.highlightColor)
    // align first line with page indicator
    y: Math.floor(_preferredHeight/2 - metrics.height/2)
    anchors {
        right: parent.right
        rightMargin: pageHeader.rightMargin
    font {
        pixelSize: Theme.fontSizeLarge
        family: Theme.fontFamilyHeading
    TextMetrics {
        font: headerText.font
        text: "X"
Item {
    // Extend extraContent to the full area to the left of the title.
    anchors {
        left: parent.left
        leftMargin: pageHeader.leftMargin
        right: headerText.left
        top: parent.top
        bottom: parent.bottom
Or before the actual someTitleFromVariable string is set perform a length check and if it exceeds lets say 50 then use something like .substring JS function to trim the string (https://www.w3schools.com/jsref/jsref_substring.asp)
truncationmode is the property
and .fade is one of the enum values
elide: Text.ElideRight
It’s actually already set in the Label:
width: Math.min(implicitWidth, parent.width - leftMargin - rightMargin) truncationMode: TruncationMode.Fade
The OP is saying the PageHeader is up multiple lines.
Thank you all for the reply’s.
Okay, since there is no easy trick or qml option, I will go with the suggestion of a little javascript snippet.
My first option was QML, it should work only takes 30 seconds to do.
substr(0,pos)
tjats all you need or ?
Just to share my solution:
