Packages need to be deleted in order to update to 4.3
REPRODUCIBILITY (100%):
BUILD ID = 4.2.0.21
HARDWARE: X10 II
UI LANGUAGE: German
Message tells me to delete package feature-xt9 and ofono-alien-binder-plugin.
I updated all public releases of Sailfish OS 4.
  1. go to settings
  2. load update via w-lan
  3. receive message
Download without warning.
There is the option to install the update when I swipe down. I did not do it yet because of the message.
What are these packages for? Should I delete them? If yes - how?
I don’t know much technically, but I’ve gotten that message before and just did “ok” and it was fine … It probably just conflicts with some other package update or something, and they will be replaced with new version.
If you have some openrepos repositories active please disable them manually for this update.
Else just update.
Please see for some insights here
