REPRODUCIBILITY (% or how often): always
BUILD ID = OS VERSION (Settings > About product): 3.4.0.24
HARDWARE (Jolla1, Tablet, XA2,…): XA2 Plus
UI LANGUAGE: English (US)
(This is just a minor annoyance, but…)
The organization of shortcuts in the Top Menu (Pull down Top Menu -> Select Gear in lower right -> Organize) gets reset after a reboot.
You need shortcuts in the Top Menu.
Maybe you need Aliendalvik Control installed and present as a shortcut.
- Reorganize the shortcuts in the Top Menu from their default
- Reboot
- Observe the organization being reset to its default
The organization of shortcuts to be remembered across reboots and restarts.
The organization of shortcuts gets reset to a default order.
