Optimise the "Do not disturb" mode by entering exceptions
Hello all,
I’m a big fan of Do Not Disturb mode, however I’m a bit spoiled by its capabilities from my time on the slippery slope (apple).
On sailfish os, the function is quite simple and basically works great, but I think it would be a very good thing if you could extend the whole thing with exceptions.
Possible ideas:
  • option calling twice puts through
  • with favourites, the device rings normally.
I would be very happy if the ideas could find a way to be realised.
Many greetings
For 2):
https://openrepos.net/content/coderus/personal-ringtones
Sorry for my late reply.
Thanks for the link, it does what I need :slight_smile:
I just thought it was a good idea to add features like this to the core.
With kind regards
+1. Do Not Disturb needs exceptions. A few contacts, like close family, should always get through, and ideally a repeated call within a few minutes too. I would also like to choose what is silenced: ringtone, notification sounds, LED. Without this I keep the phone fully on at night, since I can’t risk missing an emergency call.
Implemented long time ago. Just use favorite for contacts and enable that in the DND Settings.
Is this also activering the noyification for SMS or other messanges from those contacts or only phone calls?
Is this also applied for silence mode?
I have an emergency sms alert from an organisation and I want to make sure, that a received message is always signaled with sound on.
No way.
I use Favorites for fast access, for example, for suppliers.
But, for sure I don’t want then to ring in the church…
No clue what problem you have with the choice to allow calls from favorites.
