OpenVPN sets broken routes and disables IPv6
REPRODUCIBILITY: Always
OS VERSION: 5.0.0.77
HARDWARE: Jolla C2
UI LANGUAGE: English
REGRESSION:
When using openvpn the interface configuration is not done by openvpn itself but using a different method. IPv6 is disabled regardless of the ‘Disable IPv6’ configuration and a IPv4 route to the DNS server pushed by the VPNAC and a default route is configured directly to the interface instead via the gateway. This causes that arp requests for any ip address are sent instead of sending the packets to the gateway. Removing that incorrect default route and setting it correctly fixes the issue temporarily, but the incorrect route keeps reappearing after some time.
A VPNAC setup with openvpn (assume its IP address is 2001:db8:1000::1) in server mode using the following configuration:
/etc/openvpn/openvpn.conf
cd /etc/openvpn
mode server
tls-server
port 10666
proto udp6
dev tap
ca CA.crt
crl-verify CA.crl
cert server.crt
key server.key  # This file should be kept secret
dh dh2048.pem
verify-client-cert require
ifconfig-ipv6 fe80::1:1/64 fe80::1:1
ifconfig 192.0.2.254 255.255.255.0
client-config-dir clientinfo
client-to-client
keepalive 10 30
cipher AES-256-CBC
user nobody
group nogroup
push "tun-ipv6"
/etc/openvpn/clientinfo/sailfish
push "ifconfig 192.0.2.1 255.255.255.0"
push "ifconfig-ipv6 fd00:cafe:1337::1/64 fe80::1:1"
push "ifconfig-ipv6 fe80::1000:1/64 fe80::1:1"
push "redirect-gateway def1 ipv6"
push "route-ipv6-gateway fe80::1:1"
push "route-gateway 192.0.2.254"
push "dns server 1 address 2001:db8:123:456::1"
push "dns server 2 address 198.51.100.10"
A certificate with ‘sailfish’ as CN issued to the C2
Setup a VPNAC as stated under preconditions
  1. Go to VPN settings, add a new VPN and select OpenVPN
  2. Tap skip
  3. Type in ‘OpenVPN’ as name, 2001:db8:1000::1 as address and select CA.crt as certificate
  4. Tap advanced
  5. Select key and certificate
  6. Set protocol to UDP
  7. Port 10666
  8. Set Disable IPv6 to no
  9. Type AES-256-CBC as cypher algorithm
  10. Set device type to TAP
  11. leave the rest as it is
  12. Connect the vpn
A vpn0 interface appear configured with 192.0.2.1/24, fd00:cafe:1337::1/64 and fe80::1000:1/64
Following routes configured:
  • default via 192.0.2.254 dev vpn0
  • default via fe80::1:1 dev vpn0
  • 2001:db8::1000:1 via fe80::1 dev seth_lte0
A vpn0 interface with 192.0.2.1/24, 169.254.12.34/16 and disabled (via sysctl) IPv6 appears
Following routes:
  • default dev vpn0
  • 198.51.100.10 dev vpn0
  • default via fe80::1 dev seth_lte0
Developer mode turned on to access the terminal
Using tcpdump reveals, that only ARP requests are received on the server (and other connected clients) like
ARP, Request who-has 198.51.100.10 tell 192.0.2.1, length 28
I managed to get IPv6 to work using a script run by a systemd service. It also does a workaround for the non-working default route.
That scripts looks like this:
#!/usr/bin/bash
sleep 3
# enable IPv6
sysctl -w -q net.ipv6.conf.vpn0.disable_ipv6=0
ip addr add fd00:cafe:1337::1/64 dev vpn0
# Add a route to the VPNAC
ip route add 2001:db8::1000:1 via fe80::1 dev seth_lte0 || true
# The original default route has metric 1024
ip -6 route add default via fe80::1:1 dev vpn0 metric 256
# Remove non-working route to DNS server
ip route del 198.51.100.10 dev vpn0
# these two routes have a higher priority than default
ip route add 0.0.0.0/1 via 192.0.2.254 dev vpn0
ip route add 128.0.0.0/1 via 192.0.2.254 dev vpn0
systemd service unit:
[Unit]
Description=Openvpn address configuration
After=network.target
BindsTo=sys-subsystem-net-devices-vpn0.device
After=sys-subsystem-net-devices-vpn0.device
[Service]
ExecStart=/usr/lib/systemd/openvpn-up
ExecReload=/usr/lib/systemd/openvpn-up
Type=oneshot
Restart=no
[Install]
WantedBy=sys-subsystem-net-devices-vpn0.device
