OnePlus Two - my community port
If anyone can add it to MER wiki please do
Current release: Prebeta 3 (Stable) - Sailfish OS 3.0.3.9
DOWNLOAD:
-CM-13: Use this version - https://drive.google.com/open?id=0B34Kseus4HL2WW1lYVktOUkzMFU
-Sailfish OS: Download latest public release from OnePlus TWO - Sailfish Releases – Google Drive
How to flash:
  • use latest TWRP
  • Wipe system/data/caches
  • Flash CM-13 zip
  • Make sure System partition is mounted
  • Flash Sailfish OS zip
  • Reboot and test
Local Manifest:
https://drive.google.com/file/d/0B34Kseus4HL2cWxncS1KbU1kRHM/view?usp=sharing
My port GIT:
https://github.com/nyl/android_kernel_oneplus_msm8994 (done for now)
https://github.com/nyl/droid-hal-oneplus2 (done)
https://github.com/nyl/droid-config-oneplus2 (done)
https://github.com/nyl/droid-hal-version-oneplus2 (done)
Thanks for your efforts…do you have any idea if this will install on a newer generation One plus device like a 7 Pro?
No don’t try it, only install if it specifically states your device model (especially be careful with newer 1+ models as there tend to be three variants.
