On Android, keyboard remains displayed when an alarm sounds
BUILD ID = OS VERSION (Settings > About product): 4.1.0.24 (Kvarken)
HARDWARE (XA2, X10, X10 II, …): Xperia 10 II - Dual Sim
UI LANGUAGE: English
If an alarm sounds and an Android app is being used with the keyboard displayed, Android application is minimised but not the keyboard. You have to minimise yourself the keyboard to dismiss the alarm.
  1. Set an alarm
  2. Open an Android application
  3. Click on any field to display the keyboard
  4. Alarm sounds
  5. Application is minimised
  6. Minimise yourself the keyboard
  7. Dismiss the alarm
As on an native application, application and keyboard should be minimised to interact with the alarm.
Only the Android application is minimised, but not the keyboard.
