Hi.
In order to attempt to debug a battery drain issue, I’d like to try older versions of SailfishOS.
Does Jolla provide downloadable older versions of SailfishOS?
If not, I found this repo which contains images, but I’m not sure it’s legit.
Does Jolla provide a check sum (md5 or another) so that I could double check whether the image from this GitHub repo is the original from Jolla?
Thanks.
