Can Jolla push the notification from this Forum to the Notification tab of our SailfishOS devices with Jolla account active?
Or in alternative, can the SFOS forum app fetch the notifications and show to the Smartphone/Tablet eventview?
Thank you
Thank you
If nothing has changed so there is no API to show notifications on eventsview.
If you mean general notifications the forum app could do that by polling. But that’s feature request for
GitHub - szopin/harbour-sfos-forum-viewer: SFOS Forum Viewer or @szopin may have something to say?
As long as you keep the app open and have automatic checking of notifications checked you should get notifications in the interval you decided on
Thanks. Jusy updated to last version: it adds login feature and now notifications come from the app itself.
