Is there a note application that also has copy and paste capabilities included. I have tried Notes and Foil notes which do not have copy and paste included
I guess you could use Editor. as a note app.
Huh? Copying and pasting doesn’t need the apps to do something special. That’s handled by the OS, and works just fine in notes.
Thanks @eson, but I’m wandering why app needs so much access permissions. For example microphone, can I talk and editor change it to text.
Thanks @attah , What a fool I was.
Please try to keep to one question per topic. This has been asked many many times before and has a good answer (in those threads).
Because app developer didn’t implement Sailjail yet.
No, not with Editor, you’ll need Speech Note for that.
I,m very sorry. I try to be carefully.
Thank you for the explanation and link to Speech Note.
I use Jolla “notes” and copy and paste to it very often.
OS is still sorely missing Cut function, though.
It’s allergically clumsy to move a block of text in Notes.
Cut could fairly easily fit as a scissors icon next to copy/paste, or an additional entry next to current Clear context menu entry.
Nah. Just hit backspace after selecting.
The button/icon you refer to is only paste. Copy is automatic.
FoilNotes allows to copy the entire note to clipboard without opening it:
