BUILD ID = OS VERSION (Settings > About product): 4.0.1
HARDWARE (Jolla1, Tablet, XA2,…): XA2
UI LANGUAGE:
When you have two or more Nextcloud accounts with the same login name, all accounts look the same.
- have accounts on two or more Nextcloud instances with the same login
- Add first Nextcloud account
- Add second Nextcloud account
- Try to interact with it, e.g. upload an image or add a contact
- you can select the account you need
When trying to upload a file:
When trying to create a contact (if you’re lucky you can judge by addressbook name unless it is default):
There are a few ways for a solution:
a) offer the user to specify a name
b) read the instance name from Theming capabilities (might still be duplicate if left to default)
c) use login@domain.name as indicator
d) a) if set, b) when no duplicates, c) as fallback
Didn’t spot it although looking at it often… blame me being tired while it being late.
