No verification code to continue configuration of Fernschreiber
Continuing the discussion from [Feedback] : SailfishOS 5.2.0.18 and Apps : List problem:
Fernschreiber : Asked a code with my phone number and no code came from. Fr +33
Has your phone network access? Which model do you use? Did you set a security password? Do you have another Telegram client which is already configured?
Official telegram also does not send codes by SMS for me. It’s asking for a premium account to pay the cost of the SMS.
Forkgram crash instead.
You’re right, it sends a verification code to all connected session.
So, fernschreiber need another telegram client openned to have code ?
Unless you’re creating an account. Not sure although what are all processes to login.
It work with secondary device method authentification.
Take a photo with another phone of the generate QRCode.
Open signal from Android (AAS) and scan the QRCode from other device.
