REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.64
HARDWARE: Xperia 10 III
UI LANGUAGE: German
REGRESSION:
I added a second user to the device. I cant see any of the android apps (laybe these must be installed again caus of sandboxing?) and also USB doesn’t work. The device can’t be accessed via PC and also doesn’t find attached USB storages (that work when beein loggen into the device as defailt user)
beeing loggend into the devide as a second user (not default user)
- try to connect the device via usb to a pc.
- attach an usb stick
*device shpuld show up in Windows (10) explorer
*connected usb storage shows up in SF file manager
phone isn’t visible in Windows explorer, usb storeage is noch visible for the device
none
I know these are in the and three problems, but they seem to be caused from that non-default user in general.
