No sound from loudspeaker when outgoing call JP2
REPRODUCIBILITY: Always when outgoing call
OS VERSION: 5.2.0.18
HARDWARE: Jolla Phone 2026
UI LANGUAGE: Dutch
REGRESSION: From first outgoing phonecall
No loudspeaker-sound when outgoing calling
From 07.09.2026 I use my JP2 as my daily driver. From the first outgoing phonecall I realized that there was no sound from the loudspeaker during dialing and afterwards. I had to switch OFF the loudspeaker till the moment of answering by the other one, then I could switch ON the speaker and there was sound. Are there more JP2-sailors that have the same problem? Is there any solution to this problem?
  1. Just make an outgoing phone-call with loudspeaker switched on and there will be no sound
  2. Switch loudspeaker OFF and wait till the call is answered
  3. Switch loudspeaker ON
The phone should give dialing-sound during dialing when loudspeaker is switched ON
No sound at all during dialing when loudspeaker is switched On, not even when the call is answered. One has to switch On the loudspeaker immediately when the call start answering.
none
Does loudspeaker works in CSD test?
Is there any change in newer versions?
I don’t know what CSD test means. Sometimes loudspeaker works from the start, sometimes after the call has been answered.
Still have to install latest update 15.2.0.22. Maybe that solves this (little) problem too.
I once had an issue on my JP2026 where callers couldn’t hear me, and I couldn’t hear them. The solution was to restart the audio system using the built-in helper tools.
I started keeping a diary on my phone to track these issues and how often they occur, which could help with debugging or identifying regressions.
I have notice same Problem.
When start callind you hear dialing sound, if you press speaker on phone goes silent and then phone is silent. No dialing sound, no soun if person you are callin is answer, no nothing.
If i start calling and wait that person is answered and then put speaker on everything works as normal.
This problem is everytime when i have tested this
That is exactly what also happens on my JP2
