BUILD ID = OS VERSION (Settings > About product):
HARDWARE (XA2, X10, X10 II, …): 4.2.0.21 an erlier
UI LANGUAGE: German
REGRESSION: (compared to previous public release: Yes, No, ?): it’s persistent after upgrade from Koli over Kvarken to Verla
choose SETTINGS-APPS-CAMERA there is no possibility to choose my mounted SD Card “Speicher: Der gewählte Speicher ist nicht verfügbar. Der interne Speicher wird stattdessen verwendet.”
In other apps sd-card works fine.
I can’t find ANY possibility to choose something regarding storage folder in camera app!
have a look (screenshot)
it’s (theoretical) possible in “SETTINGS” swipe to the right “APPS” tap on “CAMERA” … et violla
It worked fine till Sailfish 4.x
Even there is no possibility to uninstall an reinstall camera-app (wich probably will solve the problem)
here is a screenshot of the memory-settings
The item “Speicher” (Storage) should have the text “Device memory” also when there is no memory card inserted in the phone. This is OS release 4.2.0.21.
Would unmounting/remounting and/or rebooting the phone help?
Can apps like the Sailfish File Browser save files to the card?
Right, release 4.2.0.21 but it was the same since Koli.
mount/umount doesn’t help, reboot similarly
data access is fine on sd-card (several audio players, videos, even andoid apps use sd-card in r/w mode)
Solved, thank you so much @treeman ! found settings now and set it to memory card.
