No response after entering SIM card PIN during bootup
When entering PIN for the SIM card during bootup, nothing appears to happen after pressing the āœ“ button for several seconds if the entered PIN is correct. Would be nice to get some feedback.
True. On earlier devices SIM input was semi-immediate so there was no need for extra feedback, but on some specific newer devices there is a notable delay that would benefit from some kind of visual indication (also slow registration should not block user from continuing to other tasks). Ideally the delay gets fixed in hardware adaptation level, and not worked around on UI.
The UI could at least show the spinner while waiting, so you know that your input is being processed.
@ender: I agree to the idea with the spinner, but @jpetrell continueing with other things before PIN input to both SIM cards is done is not a good idea. In case of entering a wrong PIN, the error message will override my screen while I’m already doing other things.
