Hi
my C2 doesn’t make any phone call and don’t receive any.
2,3,4g works but no phone call, network problem in both sim card.
try a different sim, still problem.
try 2g, 3g, 4g still the same. Network problem.
any help? My c2 has only 10 days life and start probem.
tks
If there is no network at all maybe there is one bug which stop ofono service. That happens sometimes right after sending SMS. No time right now to search that topic but if you search ofono you’ll find it.
It’s maybe better to reset and start again from the begin?
Now, here is the topic.
Much info is missing. What did you do just before problem occur? Version? Tests done? Is there an icon indicating 4G, 3G or 2G.
So I’m just guessing without that.
I don’t remember what I did, just install some software from repositories. Sfos 50061 and 4G indicating.
That might influence. What software exactly?
Some sw from chum and store man. Nothing dangerous, don’t remember details. I still not have developer setting on, and I don’t understand how this could happen.
Install ‘install history’ from chum and you will have list of what you installed in Settings app
Yeah I don’t containers is ‘nothing dangerous’ About 'Larger clock font on home screen' patch on C2 - #19 by eson
Do you have any advice? Any help?
It’s at least a bit dangerous to install/change a lot at once. Especially before IDE is released for version 5 as rebuild needs to be done for almost all packages.
Yes, my fault. But now what I can do? This is my lesson. I was curious about new sfos after my past phones with Maemo and Meego.
If you just installed just start from scratch and treat openrepos/chum as dangerous, both qt5.15 and containers are pretty risky on 486 and on C2 it seems, just keep to jolla store and you will be fine (just make a backup since your phone still works and restore it after reflash)
edit: alternatively go through each and every package in install history right from before installing containers and uninstall manually from terminal with pkcon, maybe could restore it back to functionality, not really sure which will be faster
How did you install anything from OpenRepos (e.g. by the help of Storeman) or the SailfishOS:Chum community repository (e.g. by the help of the SailfishOS:Chum GUI app) then?
I.e., did you really download and install all these packages manually?
BTW (WRT "I don’t understand how this could happen"), all this is software in “alpha” or at most “beta” state: OS, apps etc.
Side note: “[no] IDE is released for version 5 [yet] …” means “The Sailfish-SDK for SailfishOS 5.0 is not yet published by Jolla.”, while nicely pointing out the consequences.
LOL: quadruple fault ![]()
P.S.: I suggest to start anew by freshly flashing SailfishOS on this device.
Thanks… In the alternative way do I need the developer account? Right now I’m not using the terminal
No, pkcon should trigger the GUI PIN confirmation, but yeah, you will need terminal which comes from developer mode, olf posted good question how did you manage to install OR/chum and all that sh*t with developer mode off??? You can install toeterm rpm from manual download, but you still need to at least checkbox the other sources in settings (and no clue how devel-su behaves then… actually curious now)
Could you type, or show me, a right procedure to do it? I do not have dev account and also I don’t have dev experience and knowledge.
Thk
In terminal you just type ‘pkcon remove xxx’
where xxx is all the names from here from where you installed containers:
After each command you should get silica prompt to confirm with your PIN (or fingerprint, no idea), this skips the devel-su requirement, but you still seem really quiet how you managed to install all dev stuff with never turning that on, please share maybe aurora users can enjoy dev mode with just clicking around too
edit: and yeah the process is long you might save time by just doing a backup and starting fresh as it’s not even guaranteed to revert everything to working condition
